My TV won't turn on, how do I figure out if it is a blown fuse?
  • 8,617 Answers
You should be able to see if the wire inside the fuse is blown the fuse is usually right next to the power cord. What is the model number of your set?
Posted on Jul 22, 2008
WON TURN ON
For the first step, try using the button on the TV itself.
Secondly, check if the power cord is snug, and not burnt. Sometimes after a blackout, there would be a power surge, and that might burn your plug.
If both doesn't work, the fuse in your TV may be blown, or the Power Supply may also be burnt too. If this happens, you're going to have to hire an expert to help replace the broken parts.
Note that in some TV models, the fuse can be replaced by users. If this is your case, try checking the fuse to see if it's blown or not.
Feb 02, 2014 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Won't turn on
if no power indicator at the front panel it could be power supply failure, check for blown fuse. if just blinking look for leak or bulging capacitors then replace it.
Sep 27, 2012 | Toshiba 32C110U 32 in. LCD TV
My pansonic tv model ct-13r37s won't turn on by
if their is no any power indicator at the front panel the cause is either the primary fuse at the power supply section blown. and then if the fuse is blown that was mean the regulator transistor and the horizontal out put transistor could also damaged. this case can be hand held by trained technician. if you want a do it with your own just make sure you have at least a basic knowledge in electronic repair since you are dealing with some high voltage parts a care must be needed.
Aug 12, 2012 | Televison & Video
Tv won't turn on like it's unplugged but it's not
I have seen the same problem with my tv's and the like. Depending on the age of the unit, I could sometimes find a blown fuse inside (safety feature). Many electronics especially tv's are extremely fussy about power surges. Even times when I knew there was no power surge, I would find a blown fuse inside the unit, keeping power from ever reaching it's destination. Like you said. tv behaving like its off because no power getting through
Mar 25, 2012 | Fusion FUS37LCR 37 LCD TV
Tv won't turn on
Hello
Chech whether AC power get into the power supply regulator section. Just open your tV, and check it. There is a fuse [ glass cartridge type] on the power supply section. Check whether it has blown up or not. If blown up, make sure that there is some shorted components at the power supply section check it.
Feb 27, 2012 | Televison & Video
Sony 6060F blown fuse
hello!
there is a standard procedure for proper replacement of blown fuse: CRT TVs: unplug degaussing coil, replace blown fuse with 2amp fuse and turn on the set. If it works, reconnect degaussing coil, replace the fuse with correct value(5-8) amp, depends on model(see fuse note next to holder). Enjoy the show! If in a process of replacing the blown fuse with 2amp w/o degaussing coil it blows again, forget about the next step. Set need repair. It could be an easy one, replacing 1 or 2 shorted diodes or bridge rectifier, but could be real piece of work if the power supply got "fried". If your knowledge won't go further, than fuse replacement, I'd recommend local TV repair shop.
good luck,
Alex.
Jan 15, 2012 | Televison & Video
My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
N my 06 sportster Roadster tried to crank her up motor turned heard a pop then no lights ,it won't even turn over
There's a fuse panel either under the seat or behind the triangular plate on the left side of your bike. If you find a fuse blown or the main circuit breaker tripped, you'll have to figure out what caused it.
Good Luck
Steve
Jul 15, 2011 | 2006 Harley Davidson XL 1200 C Sportster...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
