Question about Sony VAIO PCG-K35 Notebook
Technical information i have a laptop that is not coming on even the power suply when is plug into the laptop the charging LED doesn't light on. There is voltage from the power supply of 19.5 v dc. In the lap top, i checked at the charging terminal and there is no voltage across.
  • Anonymous Sep 03, 2008
Thanks, but there is voltage across the jack on the mother board and even across the diode after the fuse on the board. Please futher explain other possible causes.
Posted on Jul 30, 2008
    Scholar:
  • 162 Answers
If the adapter is working, the problem could be the jack on the back of the notebook. The nice thing is most of the Vaio notebooks the jack is replaceable without having to solder the jack to the board. I would call SONY regarding the jack for a mode number and a picture. it's easily replaceable but requires the disassembly of the notebook.
Posted on Jul 25, 2008
So I bought a HP Pavilion tx2510us about 5 years ago and it served me well for the time being, but about a month ago I was using my laptop and I noticed that the battery icon showed it wasn't being...
You might check your device manager to see if there are any clues there before trying a new battery. Also, check your Power Options settings and see if there is a conflict.
Mar 18, 2013 | Computers & Internet
My hp laptop don't turn on even the charger is
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 02, 2013 | Computers & Internet
How to dis ismbel lp laptop made in 2008
There is no fuse inside the HP laptop.
Feb 04, 2013 | HP Computers & Internet
The adapter stopped charging my laptop due to a faulty wire, I bought a new adapter and now as soon as I plug in it starts for a second and turns back off. The charging light blink and it doesn't
Jan 28, 2013 | HP Compaq Presario C509NR Notebook
Have a sony vaio the wont turn on, nor will any lights come on.
Dec 01, 2012 | Sony VAIO EB Series Notebook
Dell Inspiron n7010 doesn't charge at all
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 19, 2012 | Dell Inspiron Computers & Internet
Dv-7 is not getting charged . even the white indicator on the side near charging port is not coming ON. checked the ouput of the adapter, its fine but as i hook it up there is no response .
If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.Thiscan be repaired but it requires the laptop to be completely dismantled to getat this power socket and repair. If you cannot DIY then I suggest you get aquote first.
Nov 03, 2011 | HP Pavilion dv7-1245dx Notebook
When i plug laptop in charging light come on then goes off also in bios mode the left batery says charging but show no sign of charging ...so is it the battery or what
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Jul 11, 2010 | Dell Latitude CPX650 Notebook
Won't turn on. Battery is plugged in and lit. n
Try removing your battery pack. Then connect the power adaptor (even without the battery) and connect is directly to the power outlet. If it powers up, then the battery pack might be defective or totally drained.
If the battery is just totally drained, simply place the battery to the laptop. Do not turn the laptop on. Plug the power adaptor to the laptop and plug it to the power source. If you see that the charging LED is blinking in your laptop, then just leave it charging up to 5 to 8 hours.
Never use a laptop on battery mode while it is plugged in to a power source. This is the number 1 reason why laptop batteries don't last longer.
Jun 06, 2010 | Sony VAIO Notebook
Put in a branbd new battery. Power adapter is OK.
Your motherboard does not need replacing provided the problem is the power socket on the motherboard.
If the power adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 15, 2009 | Compaq Presario 3045US Notebook
Sony VAIO PCG-K35 Notebook Logo
133 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
