Advent laptop overheating
My daughter's seven month old advent laptop keeps overheating and shutting down. The connection for the charger gets really hot and has now started to make the screen flicker when on?? Any ideas.
Thanks m
    Genius:
  • 2,028 Answers
Check the jack on the machine to see if it's loose or broken. Use a small screwdriver, and see if you can move it in any direction. If it is loose or broken, get it fixed imediately. A loose or broken jack can create an electrical arch which can do severe damage to the machine.
Posted on Jul 22, 2008
My Toshiba c650-18k laptop is just 1 month old i was playing on it and when i went to shut down before shutting down it turned off automatically and when i tried tom turn it on it is not turning on.I tried...
It sounds like your charger is not working. If you can check the voltage out of the charger or if there is an indicator on the charger that would be my first place to look. Only do simple checks as the and it should still be under warranty being only a month or two old. If you have another charger that would fit then try swapping it out to get you going in the short run. You can always warranty old charger. Or if you bought it locally consider returning it to the store.
Jan 09, 2018 | Computers & Internet
Acer Aspire 7520, running windows Vista, keeps overheating and shutting down. It is fairly new - less than a year old. Does not run for much more than 20 minutes before shutting off. It was purchased in...
Sounds like there is dust where the cpu fan is and its blocking the ventilation path in the laptop. If you can take apart the laptop to expose the fan, I would make sure the fan is free of debris. Clogged CPU fans will cause the laptop to overheat cause the air has nowhere to go.
If you do that and the laptop is still overheating then the motherboard is going bad unless your not using the correct charger for it. If you use a charger that puts out more voltage then whats needed then that could cause the laptop to overheat so you might need a new charger.
Apr 15, 2010 | Acer Aspire 7520-5185 Laptop
My dell inspiron 1525 keeps turning off and shutting down without me doing anything. why?
The computer has a cpu fan that can get dirty over time. It's job is to keep the cpu cool. When the cpu overheats, the computer senses it and shuts it down immediately, to prevent permanent damage to the cpu. You can clean it by blowing compressed air into it, and should do that every few months, as routine maintenance. This is the most common thing that shuts a laptop down, other problems involve repair, so try this first. I bough a $7 three inch fan at Walmart to help cool the laptop, and when I run it, I never have it shut down on me, but once in awhile it will without the fan, especially when I play dvds or videos, which really work th' heck out of the cpu. There are also commercial laptop cooling devices, but my little fan works just fine. Hope this helps.
Mar 29, 2010 | Dell Inspiron 1525 Notebook
Laptop turning off unexpectedly
check the oporating system... or re install the os.. if there is problem from the hdd.... or hardware problem..
Sep 10, 2009 | Computers & Internet
Laptop shuts down often when using battery power
Often, this would be a battery problem given the age of the laptop. A way to verify is if the AC adapter/charger is plugged in and the problem persist, then it would be "something else".
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 27, 2008 | HP Compaq Presario v3000z Notebook
Laptop shutting down
A quick fix is to blow back into the vents to blow dust out.
May need to dismantle though and clean fan and maybe even remove heatsink and renew thermal paste.
Jan 06, 2008 | Computers & Internet
Computers & Internet Logo
232 people viewed this question
David Payne
David Payne
