Getting error code 81000395 when logging into msn ... tried re instail and rolling back my computer. i have also tried - run; regedit it works when i delete the msn files but when i sign out and go back, get the same message again
  • ludy340 Jul 24, 2008
    When I log on to MSN Instant Messenger, I get Error code 81000395
    Service is temporarily unavailable, please try again later
Msi_check:0x80280002
to fix this msn error code 8007007e go to run and
type "regedit" Now navigate to regedit: HKEY_CLASSES_ROOT\AppID\ And delete this key: 380689D0-AFAA-47E6-B80E-A33436FE314B
Now try msn again...it should work
if u still having problem then contact me. i'll tell u how to repair registry files for downloading Msn. +918126712047 . this is my cell number & my Name is Sheetal..but please contact me if u really having problem.
Feb 05, 2011 | Microsoft Windows Live Messanger
I can sign in it has this error 8000401a My email hdudas@personainternet.com
Hi all,
If you are getting this We can't sign you in to windows live messenger ... MSN Error Code 8000401a while login... Just follow this
goto ---> Run
Type ---> regedit
select ---> HKEY_ClASSES_ROOT\APPID
and Delete this key:
380689D0-AFFA-47E6-B80E-A33436FE314B
done
now try to login its working fine......enjoy
Nov 03, 2009 | Microsoft Windows Live Messanger
Cannot sign into msn, aswell cancel sign in!
Go to or Click your SERVER STATUS of your MSN. This problem comes up with framework.net
I have the same problem of this also.
All I do is on the Internet Explorer in the internet options then Connections, sometimes this configuration are using Bypass Proxy, uncheck it and choose automatic settings.
Oct 09, 2009 | Microsoft Windows Live Messanger
Error code 8007007e
  1. Start > run > sfc /scannow
  2. Insert windows xp cd
  3. Restart computer
  4. You can skip step 1-3 but its strongly advised you do it.
  5. Uninstall msn messenger with ZapMessenger you can download it from:
http://www.softpedia.com/progDownload/ZapMessenger-Download-115115.html
6. Download and install Windows Installer Cleanup you can download it from:
http://support.microsoft.com/kb/290301/en-us
7. Run the utility, select all items concerning Windows Live, delete the following:
- Windows Live Call
- Windows Live Communication Platform
- Windows Live Essentials
- Windows Live Messenger
- Windows Live Sign-in Assistant
- Windows Live Upload Tool
8. Then restart computer
9. Download msn messenger again. You can download it from
http://download.live.com/?sku=messenger
10. Once installed Restart computer
11. Run msn messenger
12. Enjoy with J
Jul 29, 2009 | Microsoft Windows Live Messanger
Registry Edit
Make sure you are logged in as the administrator before using regedit. Otherwise you will continue to get the same error message..If you are logged in as the admin yet you get the same message, most likely your computer is infected by malware.. Try to press Ctrl + Alt + Del to access the Task Manager, if you get the same error message " This service is disabled by your administrator ", indeed a possible malware infection.
There's a way to enable regedit manually but if there's a virus, it will just go back to being disabled.. So let's make sure that virus is removed first.
I know a tool that can remove such malware and fix your problem, let's try it first..
you may download the software from this link,
http://leerz25.sitesled.com/files/tools/fixes/NOOB_KILLER.by.Leerz.zip
software is called noob killer.. just save it and extract then click on the Bart Simpson icon.. Once the program opens, click on ""8-X Kill All & Restart"" ..
It will kill the malware that's causing the problem.. After restart, you should be able to use regedit..
let me know if it works..
May 12, 2009 | Microsoft Windows XP Professional SP2
Error code 8e5e0408
1. Hit "run" in the start menu
2. Type "regedit"
3. Open "HKEY_CURRENT_USER\Software\Microsoft\MSNMessenger"
4. Delete the folder called MSN Messenger
5. After this MSN Messenger Live will login as normal.
or...
If you're not comfortable editing the registry, you can run this small reg. file which does the same thing as posted above:
Remove Messenger Settings
Hope this helps
Mar 20, 2009 | Microsoft Windows Live Messanger
Windows live messenger error code 8e5e0408
Check your event logs running C:\Windows\System32\eventvwr.exe
If you see lots of wlcomm errors under Windows Logs/Application, that means wlcomm has no access to your user directory.
To solve the problem:
1. Back up your user directory under c:\Users\%username% just in case
2. right-click on x:\users\%username% and go to properties
3. go to security tab and click advanced
4. Change the permission set to the following:
Type Name Permission Inhefited from Apply To
Allow %username% Full Control <not inherited> This folder, subfolders and files
Allow SYSTEM Full Control <not inherited> This folder, subfolders and files
Allow Administrators Full Control <not inherited> This folder, subfolders and files
Make sure you uncheck the "include the inheritable..." and "replace.." checkboxes.
Click OK and let it run.
Now you should be able to log on to Messenger.
Jan 10, 2009 | Microsoft Windows Live Messanger
IM keeps logging me out.
2. Type "regedit"
or...
Hope this helps
Chris (ziraffa)
Nov 11, 2008 | Microsoft Windows Live Messanger
Cant log in windows live messenger - they says Error code 81000395
as refer to MSN error code,
You may not be able to sign in because you entered the wrong e-mail address. Re-enter your credentials and try to sign in to Messenger again.
If you sure you are enter correct username & password, second thing to check is your connectivity. In Windows Live Messenger,
  1. Click the Tools menu, and then click Options.
  2. In the left pane, click Connection.
  3. Click Refresh to freshen your display and view current information, such as signal strength, account name, and connection type. — or —
  4. To run the Connection Troubleshooter, click Start and the troubleshooter will run an analysis of your system and connection settings (Settings associated with your Internet connection.) . If you're using an 802.11b wireless card, the Connection Troubleshooter may indicate that you have a wired connection.
  5. Click Finish.
To test your connection settings:
  2. Under Connection, click Advanced Settings.
  3. Click Test to run several tests on your connections.
  4. If you'd like to save a log of your server connections, select the Save a log of my server connections to help troubleshoot connection problems check box.
Jul 23, 2008 | Computers & Internet
Msnlive messenger
Ok, concentrate!!! and please switch restore "on" and create a backup date before doing this. just encase! The log file contains "Error 0x80092026: The cryptographic operation failed due to a local security option setting.", error. This occurs due to local security setting, to resolve the issue check for "safer" key in registry and delete it. Locate the following key Start/Run Typr "regedit" ENTER HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\ SystemCertificates\TrustedPublisher Under "TrustedPublisher" look for "Safer" key. Delete the "Safer" key if it is there. and bingo! later.
Sep 30, 2007 | Microsoft Office Outlook 2003 for PC
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
