Question about Epson Perfection 1650 Photo Flatbed Scanner
My Epson Perfection 1650 Photo scanner keeps producing scans that have a 3-4 inch bright panel vertically down the middle. The image is visible, but the outer thirds are quite darker than the middle section. I've tried different scanning programs (Picasa, Windows), restarting the machine and get the same result. This is really odd because the scanner just produced several normal scans before this. Any ideas?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 305 Answers
Make sure all the scanning settings are correct first then set everything first before you preview image then hit scan.
make sure the size is correct drag the image on the prview screen make ths dotted lines frame your image then scan
remember you tell the machine what to do by setting it, if you dont the machine trys to do thevscan its self. Good luck, have fun
Posted on Mar 12, 2014
5 Suggested Answers
SOURCE:
  • 110 Answers
SOURCE: Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Posted on Aug 22, 2008
mohanchennai
  • 490 Answers
SOURCE: I have vertical lines in my photos when i scan them
If the lines are in the same location for all scanned outputs, it is clearly dust on the scanner glass. Clean it thoroughly.
S. Mohan, India
Posted on Jul 09, 2009
adnanbhatti
  • 1188 Answers
SOURCE: i need to reinstall my epson perfection 1650 but i
Copy and paste this link in your internet browser address bar and you will be taken to the site to download all the needed drivers:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14551&prodoid=6464130&infoType=Downloads&platform=Windows
Do give my solution the highest rating if it solves your problem. Thank you for using fixya!
Posted on Aug 07, 2009
  • 388 Answers
SOURCE: the scanner light on my epson 1670 fluctuates in
check the power souce is conected properly it may be the bulb or pwer converter inside cheapest fix is to replace the whole unit.
Posted on Oct 06, 2010
Driver for Epson Perfection V 1650
Hello there.
You can download it here http://driverscollection.com/?H=Perfection%201650&By=Epson .
I hope I was helpfull.
Sincerely,
Steve TM
May 29, 2011 | Epson Perfection 1650 Photo Flatbed...
Do I need to uninstall my epson perfection flatbed 1650 photo scanner to reinstall it? I have xp sp3
No, you don't. If you are worried about it, you could uninstall, reboot Windows, and reinstall.
Nov 21, 2010 | Epson Perfection 1650 Photo Flatbed...
I just installed a 1650 scanner and I have no choices in the document source window. I need to scan color slides. I'm running Vista
I believe you need to change your settings to professional, right now its in automatic or beginner.
something like that
thanks adi
Dec 16, 2009 | Epson Perfection 1650 Photo Flatbed...
S. Mohan, India
Jul 04, 2009 | Epson Perfection V350 Flatbed Scanner
Scanning slides produces black images. Slide
Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
Jul 03, 2009 | Epson Perfection V350 Flatbed Scanner
Epson Perfection 1650 Photo Flatbed Scanner Logo
98 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
