Question about HP DeskJet F380 All-In-One Printer
Does my printer have a duplex option
Hi i have a hp deskjet f380, i know that print duplex you have to go to properties, but does my printer do this because when i do this it just shrinks my works and prints it out on one page. please help
  • 22 Answers
Re instal the software of your printer
Posted on Aug 26, 2008
In the past I was able to choose the Manual Option which allowed me to print on both sides. Now every time I choose this option, it goes to Off. Can you please help me with this problem?
Many printers support duplex printing, but they don't all make the duplex option available in the same way. With some desktop printers, choosing duplex means that the printer prints all of the copies of the first side of a page, then pauses and asks you to flip the sheets that it just printed and return them to the printer, after which it prints all of the copies of the second side. This method is called manual duplexing.
To print on both sides of a sheet of paper:
  1. On the File menu, click Print.
  2. In the Print dialog box, in the Name list, select the printer that you want to use.
  3. Click Properties.
Note The information in the Properties dialog box varies depending upon the manufacturer of the printer you're using. With some printers, you will see a Layout tab with a Print on both sides option on it. With other printers, you might see a Features tab, and the duplex option might be called something like Two-sided printing. Explore the various tabs in the Properties dialog box until you locate the duplex printing option.
  1. Choose the duplex printing option that you want.
The options will be called something like Long edge (or Flip on long edge) and Short edge (or Flip on short edge). Whether it's better for the paper to be flipped on the short edge or the long edge depends upon the type of publication you're printing. You might need to print a test publication or two to discover which option works best.
  1. Click OK to close the Properties dialog box, and then click OK again to close the Print dialog box and print your publication.
Sep 25, 2010 | HP Deskjet 2460 InkJet Printer
Need instructions of how to print double sided on my hp deskjet 970cxi
Please open the Contorl Panel, go to Printer, Go to Preference of selcted printer.
Or the Properties of printer. There you will find on the General Tab, Print on both Side of page option, also known as DUPLEX.
Select it and then go for print.
Scott
Apr 28, 2009 | Apple HP DeskJet 970cxi InkJet Printer
Duplex not recognised
You need to set the duplexer to installed. For Vista this would be done as follows: go to the Printers folder, Right Click on the 5550, Run as Administrator, Properties, (continue), Device Settings, Installable Options, Duplex unit (set to Installed), Apply, OK.
Once you have done this in Vista the duplexer will work but the back side may print upside down regardless of the settings. This can be corrected with a patch available here.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
Duplex printing in HP 2420dn
I had the same problem. It was due to incorrect properties in the printer settings.
  1. Go to Start >> Printers and Faxes
  2. Right-click on the HP 2420 printer and select Properties.
  3. Go to the Device Settings tab.
  4. Under Installable Options, set Duplex Unit to Installed.
Also, make sure that the Printing Preferences are set to Two Sided Printing:
  2. Right-click on the HP 2420 printer and select Printing Preferences.
  3. Go to the Printing Shortcuts tab.
  4. Select the Two Sided (Duplex) Printing option.
That should do the trick.
HP - please change your setup so that this is set by default!!
Brian Z
Mar 10, 2009 | HP LaserJet 2420 Printer
HP Deskjet F380 All In One Printer
did you choose the name of your printer in the printer option when printing in the other programs?...try it...else maybe you need to wait while your printer spool... or is it compatible with the program you are using?
Aug 18, 2008 | HP DeskJet F380 All-In-One Printer
Status: offline/online
One way to make the printer go "on-line":
1. opening your "Printer & Faxes", the HP DeskJet F380 would be shown as an installed printer, by doing a right click, you would be presented with various options including making it go online.
There are two (2) areas that you can configure to make it stay always online:
i. in the same "Printer & Faxes", right click on the HP DeskJet F380, click on "Properties", in the next window click on the Advanced tab, tick "Always available", set Priority to "1", in the "Printer" tab, uncheck "Power Save".
ii. open your "Device Manager" (right click on "My Computer", click on Properties, click on "Hardware" tab, click on "Device Manager" button. Expand your "Universal Serial Bus controllers" (click on the + sign of the last entry), right click on each and everyone of your "USB Root Hub". Click on "Properties", click on "Power Management" tab, uncheck "Allow the computer to turn off this device to save power".
After each and every re-configuration it is of course required that you click on Apply/OK.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | HP DeskJet F380 All-In-One Printer
Alignment problem
I want to start my office working with the HP F380 DeskJet....
Apr 30, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet 9800 will not print both sides
Yes, there should be a compatible driver for windows vista on their deiver page.
If there isn't you must buy a new printer.
Apr 19, 2008 | HP DeskJet 9800 InkJet Printer
5652 and Vista - duplex print not working
In Vista the default s the duplexer is "not installed". Go to Start, Settings, Control Panel, Printers, double-click on the Deskjet, Printers, Properties, Device Settings and set the duplexer to "Installed".
If the duplexer prints the back side upside down in Vista once it is enabled you can get a patch as described here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Feb 19, 2008 | HP DeskJet 5652 InkJet Printer
Hp deskjet f380
To print from a software application (Windows)
1. Make sure you have paper loaded in the input tray.
2. On the File menu in your software application, click Print.
3. Make sure the HP All-in-One is the selected printer.
4. If you need to change settings, click the button that opens the Properties dialog
box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
5. Select the appropriate options for your print job by using the features available on
the various tabs.
6. Click OK to close the Properties dialog box.
7. Click Print or OK to begin printing.
Nov 08, 2007 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
179 people viewed this question
Ben Johnson
