I have my setting on Warm wash/cold rinse. In the winter, I get cool wash/cold rinse but in the summer I get warm wash/cold rinse. This is just the opposite of what I want and this has done this since day one of the purchase. Even at my last residence it did it. Why does this happen.
  • 550 Answers
The hot water solenoid valve -
the hot water hose -
the filter screen in the tap /hose connector -
one of the above is likely blocked or restricted
check them in reverse order, the most likely and easiest is last
turn the water off before disconnecting any hoses to check, makes a mess
Posted on Jul 23, 2008
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
What is the benefit of wooden dog houses?
Wooden dog houses provide several benefits: They keep the dog warm during winter They keep the dog cool during summer The nice smell of the wood relaxes the dog They are durable
Sep 10, 2012 | Dogs
Can I use the same bed for my cat all year round?
The thing about cats is, like humans, they like to be warm in winter and cool in summer. This goes for their beds too. If you have a warm cozy bed that your cat uses every day during the winter, don't be surprised if they avoid it all summer long and opt to sleep in a cooler location of the house.
Jul 23, 2012 | Cats
Maytag washer will not get warm
1) the temperature coming from your house determine how is the temperature. You can get hot, cold or mix of hot and cold available to your machine.If the water is too cold affect the machine,and if is too hot, the warm temperature colapse.
If you live Northern are, unless you adjust the cold and hot verywell affect the temperatur of your machine.WARM water is better in summer and Colder during the winter.
God bless you
Jun 21, 2012 | Maytag Washing Machines
EW1200 is rinsing in hot water how do we change that
Hot wash, hot rinse is for 'whites'. Cold wash, cold rinse is for 'colors'. Warm wash, cold or warm rinse is for 'permanent press'. Check your settings to see if you have these options. Double check the hoses, put the machine on cold fill and feel the hoses.
Has someone worked on the machine and possibly put the wires on the solenoids wrong? Easy mistake to make.
Mar 10, 2012 | Electrolux EW1200i Front Load Washer /...
Cold fill washing machines
If your washer is the type that all rinses are in cold water only this would make sense that in the winter months when the water is at it's coldest the clothes will feel cold after the spin cycle.
If your washer has a warm rinse cycle and when you select the warm rinse option the clothes feel cold after the spin, then maybe the hot water supply line is plugged.I recommend disconnecting the hot water hose at the back of the washer and check the screen that is at the fill valve on the washer and make sure it isn't clogged with sediment or calcium build up or any other foreign material that would keep the hot water from entering the washer.If all is well there, suspect either the water temp selector switch or the hot water fill valve. Good luck !
Jan 23, 2010 | Washing Machines
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
No water enters on rinse cycle
I was partially wrong on my diagnosis. No cold water enters on either the wash or the rinse cycles. I also heard odd noises from the inlet valves. I realized the cold water valve was not opening. I've ordered the mixing valve and plan to replace it as soon as it comes in.
May 20, 2009 | Kenmore Washing Machines
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
