Question about Sony Grand WEGA KDP-57WS655 57" Rear Projection HDTV
9 blinks on my kdp57ws655
Used to turn the power off afew times and it would turn on now nothing but blinking 9 times. think u could give me some insight on this problem. im get mixed information. this tv is only 3 years old .
  • markeddy Nov 24, 2008
    I have the same problem. sometimes I can get it to turn on.
  • 33 Answers
Your tv have a G board problem p/n A-1065-549-A( A1065549A).
It local on the leftside of the tv looking from the back,the one has
AC cord attach to it.Sony no longer have it.PTS Electronic rebuild
for $192.00, Ebay Valleysercices rebuild for $69.00
Posted on Sep 09, 2010
My Sony KDP57WS655 standby light blinks 11 times when first turned on. The sound comes on briefly but no picture; then the TV shuts off again. After that the standby light rapidly blinks 10 times, pauses,...
laisecorp,
You have a problem on the "D" board. If you understand electronics and soldering you should check transistor Q8014 and Q8013 for shorts, leakage or bad solder connections. If you find any problems replace the transistors and also check/replace R8051 and IC8005.
If you are not good at soldering or fixing electronics go to http://www.encompass.com and purshase the board, part number A-1065-548-A. The board is $150.00 US plus shipping.
Thanks for using FixYa and for the generous rating.
hardrocko
Aug 20, 2010 | Televison & Video
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
9 blinks
D6117- Change switching Regulator on G board you can also do Self-Diagnostic Mode Press display ,5 . vol- ,power. this should turn set on and show other codes telling you what else maybe wrong. TO Remove codes and clear back out Press display,5,vol+,power Now Press 8 and Enter.
Jan 05, 2009 | Sony KP-46WT520 46" Rear Projection...
TV won't stay on, Standby blinks 10 times
Its sort of silly, but my father got behind the tv and smacked it. The error message went away, and the tv is working fine now.
It wasn't easy for him to get behind it though, it's rather tall and weighs 234lbs.
I did manage to find a pdf file of the repair manual for this model at Techlore.com.
Mar 06, 2008 | Televison & Video
My phillip 51 inch will not turn
this happened to me once i think the problem is that the button is used so infrequently that it sticks try pushing it very hard as many times as needed and id and when it comes back on dont use the button anymore just stick to the remote
Feb 14, 2008 | Philips 51PW9303 51" Rear Projection...
Blinks twice pause blinks 4 times
SYMPTOMS
Dead or Shutdown symptoms.
RESOLUTION
Dead symptom reported to be caused by the following:
1. Dead.
Found Q601 & Q602 shorted, R615 open, and IC600 on the A Board were the cause of the symptom.
2. Dead.
Found D614, Zener diode, on B+ line was shorted.
3. Set shutdown and the standby LED blinks 3 then 5 times.
Found 200v line was low. Disconnected CN706 on the C Board and found 200v now
present on CN706/pin 7.
Found: IC702 (C board) shorted the 200 volt line.
HQ Comments: C541 on the A Board could become defective if the 200v line is shorted since
the polarity on the capacitor will become reversed. R553 fuse resistor could also be opened
on the A Board.
4. Error code of 4 blinks .
Dead set press power button you hear the relay and you see red led flash 3 times and stops? Has no HV or other action. Tech removed the back as no 200 volt supply, did unplug CN706 and now has 200volts. Tech did remove the IC702 and same it comes up so needs this IC.
5. Dead. 5 blinks then 3 blinks. Found shorted Damper diode D504. Q502 has a built in damper, as well.
6. The TV does not turn On and the LED flashers 9 times.
Found one side of R610 open on the Base of Q690 on the A board.
7. Dead, 9 flashes, Q606
Would not start when cold, has stand by 5 but relay never energize.
No response from front panel or remote controls.
9 blinks is not in service manual.
Found Q606 (Zero Det.), on the A Board, had no soldered on the collector
of the transistor causing an intermittent connection.
Soldered the collector of Q606 and set returned to operation.
HQ Comments: Also refer to E30968554.
8. Dead. 5 blinks or 3 blinks
Found on the A Board D611 in the Power Supply open, and Hor. Output Q502 shorted.
9. Found Power Supply components D611 shorted causing Q600, Q601, and R615
to fail on the A Board.
10. No picture or sound. Standby flashes.
Found Q512 (Pin Out) shorted. on the A Board.
11. Dead. No sound or picture.
Found the FBT and Q502 were shorted, and R615 open on the A Board.
12. Dead
No power, Stand by light flashes 4 times.
Found T604 and IC601, replaced.
Found D611 on the A Board was the cause of the symptom.
13. Dead.
Found D534 shorted on the A Board.
14. Shutdown 4 Blinks.
Replacing R595, OCP Latch Q532 on the A Board, fixed the set.
PN 1-247-891-00, 330K 1/4 watt.
15. Unit shuts down after 15 mins.
Immediate shutdown - sometimes it give a 3 blink, sometimes nothing.
Found R595 (330K) was open located in the Q532 OCP Latch circuit.
R595 P/N 124789100 330k 1/4w
16. Won't power up. LED Blinks 4 times, B+ is very low
B+ is at 49V, +15/-15 only coming up to about 1 volt.
Wth Hor Out disconnected B+ only comes up to 50v.
17. Intermittently does not turn on
Found a intermittent C633 on pin # 3 of IC600.
C663 P/N 113647911 Film cap .001uf 100v
Billy
If you need the service manual contact me at:billyjones@fletchersite.com
Jan 27, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My TV will not turn on!
I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
Dec 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Grand WEGA KDP-57WS655 57" Rear Projection HDTV Logo
522 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
