1. your hard drive may not be compatible with the mother board
2. check the manufacturers installation set up instructions and compatibility information and see if it match you pc unit.
3. check the computer manufacturers site to see if your pc can accommodate the hard drive.
4. check the cable to see if it is connected backwards > that is is power connection to the cable getting a 5v /12 volt from the power supply> this may take a computer tech to check if you are not familiar with the electronics.
Computers that request driver downloads are restorable by performing system updates. Once activated, the computer searches to compile the entire resources required from available networks. In situations that computer requests updates least networked would require ascertaining the exact program that is missing feature to cause functionalities. An extensive program malfunction least requires updates however requires reinstallation or new program altogether. The computer displays request to capture drivers as manufacturer designer's notification. Refer with computer support experts since request for missing driver would involve incompatibility condition least updatable. For example, missing computer drivers is installable on devices that are compatible to the system alternately, computers that least allows to replace drivers as incompatible will still request for drivers from peripheral devices. In such a situation, either the device requires attaining functionality on another computer or requires acquiring device that least requires drivers to function. Refer with computer technicians experts to configure the condition.
This unit had worked fine for 2-years, with the lap top I'm using, prior to the new error report it is giving me. I'm wondering if I had done something wrong to it. I had run a de-frag on it, and it froze in the process. I had done de-frags on it before with no problem, but maybe it was just too full. Yet when I google it, many people have the similar error.
