Question about Electronics - Others
TruTech 7 inch digital photo frame
Can you tell me if there is a way to have the slideshow continue over and over again. As of right now, it shows all of the pictures once and then goes back to the menu.
Thank you,
Darleta
Setup Menu>Custom Setup>Repeat Mode>All
Posted on Oct 23, 2008
Anyone know why some thumb drives can be read by the trutech digital pix frame and some can't???
Posted on Dec 08, 2008
How to start slideshow after selecting the pictures
When you power on the picture frame, a slideshow will automatically display the photos on your memory. (If you have not inserted a memory card yet, the slideshow will display the photos pre-loaded into the internal memory.)
To restart the slideshow, press
ENTER again, or press the Slide Show button on the remote control.
May 05, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
My external is hooked up to the frame through the usb, but itwill only let me choose internal memory or slideshow folders, it wont let me choose usb when i try to select media sources. how do i get it to...
The external hard drive is diferent from a regular USB stick, so this is probably the case. You could check the manual of the photo frame and the manual of the externa drive, probably you will find some settings that reffer to this.
You could also check that the external drive is plugged in to AC, and turned on, many drives require alternative power source when conected to low power readers like your photo frame.
Apr 07, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Slideshow freezes during slideshow
I wonder if ALL the pic's are correct Size & Format?
Feb 01, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
I can't get my DP702 digital frame to save my pictures from my camera. Can you tell me how to do it ... ty
The DP702 frame only takes 14 pictures saved to the slideshow file. Install a memory card/device, then plug in the usb cable, electronic store carry it for 7 or 8 dollars. It's too bad, it doesn't come with the frame. Choose the photo you want saved, and press the save button on the remote to save the photo to the slideshow, if you press it again while you're on the same frame, I think it will delete that photo. I hope that helps.
Dec 26, 2009 | Coby DP-772 Digital Picture Frame
Pandigital Photo Frame - Slideshow leaves out Photos?
Size limit depends on exact model. Anything over 4GB will almost certainly not work consistently with any. model 1GB or less should work with any model. None of the images should be stored in folders, and all should be jpeg format (.jpg). If any of them have been edited, they may be saved as Progressive jpeg or something similar even if the extension (.jpg) remains the same. If you resave the missing photos in as JPEG in MS Paint, it should ensure they are compatible. You may have to format the memory card and re-add the photos to make sure it will work,
Sep 20, 2009 | PANDIGITAL 7" Digital Photo Frame With...
Can't get frame to read files on USB flash drive
keep the drive you use to 2g or 4g max.for some reason a lot of the cheap frames cannot handle anything bigger.
Mar 29, 2009 | Nextar N7 - 7 Digital Photo Frame with...
Order of photos
Hi, u need to arrange the photos by size or by alphabetical order in your desktop first, then u need to transfer it to ur pendrive, then plug it to ur device everything will b fine then. Rate the soln dude plz n tell me what happened
Jan 25, 2009 | Electronics - Others
7" Trutech digital photo frame Calendar
Use the Navigation Buttons to select "Calendar"; press Enter to confirm. To set the date, press the Stop Button and then use < and > Buttons to adjust the year and the arrow down and ^ buttons to adjust the month; press the Stop Button again to confirm. Then, use the Navigation Buttons to select the current date on the calendar display and press Enter to confirm. To exit press the Menu Button.
Nov 07, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Electronics - Others Logo
697 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
