Question about HP LaserJet 3600dn Printer
3600dn keeps saying tray 2 is empty when its not
3600dn keeps saying that tray 2 is empty when it is physically full. Could this be a sensor issue, if so which one..? I was thinking maybe it could be the cassette media sensor, but I can't find a parts # anywhere for it. Please Help!!
  • David M. Haines Feb 24, 2014
    after some trouble shooting i have found the relay board under the plastic cover to be the problem in most cases especially if you see tray 2 empty error part #rm1-2632 pc relay board
Pull the tray 2 out completely. The finger about tray 2 is stuck. Take yiur finger and push it until it is free and not stiff.
Posted on Jun 15, 2010
    New Friend:
  • 52 Answers
The tray 2 on the 3600 is released form its locked posotion when you push the tray in by a finger that is mounted on the metal base of the printer. If that finger is broken, or what I have found is the customer sets the printer on a cabinet or something else where the middle of the base of the printer is not supported and the middle of the base bows so the the finger does not catch the tray relase any more. I have not been able to find the part # for the finger, but all my problems have been the bowing of the base.
Posted on Feb 27, 2009
    pc relay board on bottom of unit inside under plastic cover has been the usual cause of this failure for me hp part # RM1-2632
Its the first finger sensor right above the tray 2 that gets stuck. It should move freely.
Posted on Jan 08, 2009
I was descaling my exprelia coffee machine.i was asked to empty the coffee grounds unit and the drip tray. I did that and the message keeps appearing. I even turned the machine on and off. Help.
  1. Thoroughly clean the small overflow area in the drip tray. Once the drip tray gets full water flows over a small rim into this small separate part thus triggering the sensor that tells that the drip tray should be emptied. Its waals may get a bit fatty/dirty, and so remains wet and keeps triggering the sensor.
May 23, 2014 | Saeco Exprelia Automatic Espresso Machine
I just purchased a used Phaser 8550 Printer. I used it create letters this past week. I just received the 07,010.43:37245 error message. I thought maybe there was an issue with the 'waste tray'. I...
Never had a printer fill that much before not allowing to print.
Try removing the waste tray and empty then look in the side door and see if there is any cooled ink hanging from above jammed in there and solidified, you may have some pick cleaning to do but I think you may also have a bad sensor somewhere to allow it to get that full to begin with.
Feb 11, 2011 | Office Equipment & Supplies
It says driptray full, but it isn't? Any ideas?
Wevhave had ours into the shop four times for the erroneous 'coffee grounds' and drip tray' emptying. They have changed the mother board, chip in the door and even looked at the head gasket and carburettor settings but can't find the source of the problem.
What we have found latelt (it's Christmas so everything is closed for a month) is if we leave it overnight without power, 3 out of 4 times it resets itself.
It's apain if it plays up during the day but mornings brings us a good cuppa more often than not.lesson-get a deLonghi next time, this Saeco brand is more trouble than they are worth.
Nov 28, 2010 | Gaggia Titanium Espresso Machine
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
HP 3600dn Duplexing Issue
Manual 2-sided printing. Most of the supported media sizes and types listed for printing from tray 1 can be manually duplexed. Do not use the 2–sided printing feature on transparencies, envelopes, or labels.
I found this note in the 3600 service manual. Maybe it will help.
Mar 06, 2009 | HP LaserJet 3600dn Printer
HP laserjet 8000 tray 2 not empty
Do you hear the paper "drop" when you pull out the paper tray. If not, it could be a lift motor
You will have to pull the Paper Input Unit to repair it.
Small items are not available for us to purchase.
If you can't fix, you need a new unit. About $400.00
Feb 11, 2009 | HP LaserJet 8000 Printer
Delonghi EAM 3400 keeps saying "Empty Grounds Container"
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
Dec 19, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Dregdrawer full message will not go away
Have you tried removing the drawer with the machine on, leave it out for say 2 minutes and then replacing the dreg drawer again?
There is no dreg sensor. Dreg drawer full works off a counter - depending on when the counter was last reset your drawer may be full but it may be empty.
Simply removing the dreg drawer and replacing it quickly will not reset it. The machine has to think that you have actually taken the time to empty it - a couple of minutes should cover this.
If this does not resolve the issue, you need to get a Technician to take a look.
I hope this helps
Aug 26, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Jul 11, 2008 | Saeco Talea Ring Plus Espresso Maker with...
HP LaserJet 3600dn Printer Logo
1,174 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
