P1698
Chrysler
ECM fault-No CCD message from TCM Probable Cause[s] EVAP leak detection pump solenoid circuit condition Probable Cause[s]
- Failed ECM
P1495
Chrysler
- ECM detected the pump solenoid did not change status when activated
P1698= "no CCD messages from the transmission or body controle module (TCM or BCM)"
(The engine control module or ECM is not able to communicate with the two other computers.)
P1495= "Leak detection pump solenoid circuit"
(I believe this pump is the one the EVAP system uses to pressurize its lines temporarily when it does a self check for leaks.)
The p1698 is no message received from the tcm .the po1495 is leak detection pump soleniod circut .what kind of problem is it transission slipping or shifting problem
