Question about HP OfficeJet 7310 All-In-One InkJet Printer
Print Quality When copying, the first half of the page is good quality, the second half of the same page is fadded out and not legible.
    Scholar:
  • 93 Answers
  1. In Windows, click on the Start button and choose Control Panel.
  2. Choose Printers and Other Hardware from the menu that opens.
  3. Choose View Installed Printers or Fax Printers.
  4. On the window that opens, look for your printer's name. Right click on the printer's icon and choose Printing Preferences.
  5. On the Print Quality tab, choose Draft or Fast (varies depending on the printer).
  6. If you want to conserve your color ink, choose Grayscale Printing on the same tab (just remember you'll have to uncheck that box if you want to print something in color).
  7. Press OK. That's it; now your printer will automatically print in Draft Mode (and in grayscale, if you chose that option) until you change it back. To change it, simply follow the same instructions and choose Standard for print quality
Posted on Aug 13, 2008
Poor print quality - dots on side of copies
Using refilled cartridges? avoid refilled one, remove cartridge, used blower blow out toner fallen in side,take 25 pages of blank pages print outs, then go to menu>configure device>fuser modes select clean page wait to clean it self, do this process twice or thrice till fell print quality good.. if no result replace teflon sleeve(replacing the teflon sleeve only professional can do)
Feb 01, 2012 | HP LaserJet P4015N Printer
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
Dec 26, 2010 | HP Photosmart C3150 Printer
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
Copies not very clean?
You should try to reset the printer.
You can do this by turning the power off, holding down the "menu/set" button and turning the power back on.
You will now see "maintenance mode".
Press 01, you should get para init.
Now press 99.
If this does not work, print out an internal report by pressing the "report" button and see how it looks.
If it is legible, you will need to get the machine serviced
Mar 24, 2010 | Brother MFC 7420 All-In-One Laser Printer
Slow and deliberate printing on HP 2610xi Photosmart Printer
Resolving the problem HP has created a firmware update that will correct this and other problems. The specific problem corrected by the firmware update will be listed on the download page.
NOTE: Before installing the patch, the all-in-one software must be installed and the all-in-one must be connected, turned on and ready for another task. Follow the steps below to download and install the patch:
  1. Use the Support and Drivers Web page to locate the driver download Web page for your all-in-one.
  2. Select your Windows version from the listed versions.
  3. On the driver download page for your Windows version, locate the Firmware section and click the listed Firmware update.
  4. Review the information on the Firmware Update Web page and then select the option to download the file.
  5. Click Save to save the file to the computer.
  6. A Save As window will appear. Select Desktop in the Save in box, and then click Save .
  7. After the download is complete, close any running programs and verify that the all-in-one is connected to the computer and the power is turned on.
  8. Double-click the downloaded file on the Windows Desktop to install the update.
May 21, 2009 | HP Photosmart 2610xi All-In-One InkJet...
The printed pages with black is light and spotty.
Try to run the "Clean Print Heads" utility. Sometimes it is called something else, but whenever your print quality degrades, this is a good program to run. If that doesn't work, then I would suggest replacing the print cartridge. Sometimes they go bad if they have not been used for a long time. Hope this helps!
Mar 13, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
Phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Nov 26, 2008 | Xerox Phaser 8560DN Laser Printer
Poor print quality - top half page okay, bottom print faded and skips top half page okay, bottom print faded and skips problem Just installed a new cartridge
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Jul 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
88 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
