Question about Canon Pixma iP6000D InkJet Photo Printer
IP6000D printer I just replaced a new ink cartridge (photo magenta) into the printer and shut all the printer covers. After that I still got an error message saying that the photo magenta ink has run out, and it will not print. Those were the first few tries after I replaced the new cartridge. Now, whenever I press "print" I get a message saying "collecting printer status", and the printer still won't print. Would very much appreciate it if you can help me on this. Thank you. Please send reply to pfm1@mcnamer.ca Or call 1-613-224-9910.
  • pfm1 Jul 22, 2008
    Thank you. It seems to work fine after I removed the cartridges, putting them back, then restarting the printer. Afterwards, though, the printer repeatedly printed the same thing several times before I pressed "cancel" on the printer itself. Also, I had received an error message saying that the printer was not responding before I tried it again.
  • pfm1 Jul 22, 2008
    Works fine after I followed the instructions. Thank you.
  • 319 Answers
Please shut off printer and unplug.
Restart operating system.
Power up printer.
(please be sure you removed the protective tape tab from ink cartridge!)
The printer may want to print a test page.
Good Luck!
Brian
Posted on Jul 22, 2008
  • 3,037 Answers
The following should be your reset directions for the printer. Let me know how this works, it should fix the problem that you are having if unplugging and disconnecting and reinstalling the drivers doesn't work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
    Genius:
  • 3,422 Answers
PLease make sure you clear out the print queue first.
  • Priya darshan Jul 22, 2008
    Also please reinstall your drivers once.
    Make sure that the printer is properly connected to your computer. Run Self Test on
    the printer to make sure your printer is equally ok. If test sails
    thru, run printer diagnostic test to confirm that PC/Printer connection
    is ok. Also setup your printer to start printing immediately as against
    queue up status.
    If problem still persists, completely un-install and disconnect printer
    from PC. Restart PC, when it is up and running, connect Printer and see
    if is it automatically recognised by computer.
    Goodluck..
    Please don't forget to rate or accept the solution.
  • Canon Master
  • 13,433 Answers
If your printer is still under warranty, then you can get it serviced for free.
but try, removeing the carts, close the cover, restart it, let it see that theres no carts in at all, put em back in, restart it.
  • Ekse Jul 22, 2008
    unplug the computer connection between the printer .. and restart, connect it back and try printing again.
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
ERROR6502
Error 6502 is a ink tank position error, one of the contacts for the ink tank in the carriage could be bad, or simply a wrong cartridge installed. You can't use photo magenta in a magenta slot, or photo cyan in a cyan slot.
Jul 15, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
Error message is telling us we are out of ink we just replaced
This problem needs to be addressed by an Epson service center. It needs disassembled and probably needs parts replaced that the leaking ink damaged. Sorry.
Dec 28, 2008 | Epson Stylus Photo RX500 Printer
Streaky pictures
hi, your head has damaged/need replacement. Try to clean it once again
thanks
Aug 15, 2008 | Canon Pixma iP6000D InkJet Photo Printer
My canon pixma i4300 is telling me that an ink cartridge needs to be replaced- I open the cover and the magenta cartridge is blinking- so I uninstall it - it is full of ink - I reinstall it it stops...
My canon pixma i4300 is telling me that an ink cartridge needs to be replaced- I open the cover and the magenta cartridge is blinking- so I uninstall it - it is full of ink - I reinstall it it stops blinking but the minute I put the cover back down I get the same error- Whatsup?
Aug 07, 2008 | Office Equipment & Supplies
Brother MFC 5460CN No cartridge error
The tape method worked for me on my 1960C. I put duct tape over the window in the front. If there's a place you can see ink, cover it up.
Nov 14, 2007 | Brother MFC-5460CN All-In-One InkJet...
Pixma iP4000 problem
the printhead is shot. I've replaced my printhead twice on my pixma ip6000D in just over two years.
Aug 20, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
414 people viewed this question
old marine
old marine
