Question about Pioneer CDJ-1000 CD Player
CDJ Laser Alignment/Calibration
I have a couple of CDJ 1000's (Pioneer) and over time the laser has come out of alignment/focus/calibration (whichever you would like to refer to that as). I need to know if there is anyone out there who knows the procedure to realign/focus/calibrate the laser. Thanks in advance.
They dont normally go out of focus, any trouble reading discs / freezing is usually caused by a worn out laser which will require replacement.
Posted on Sep 24, 2008
CALIBRATE LASER ALIGNMENT LB4
can you inform how i can calibrate laser level alignment lb 4
Jan 23, 2013 | Leica Laser Alignment Lb-4 Dual Grade...
Printer performs toner alignment every time it is turned on
A friend of my faced the same issue years ago with another HP AIO printer. That model required you to scan that printout. In other case - firmware "thought" calibration is not completed and was printing out head alignment/calibration page every next time printer was turned on. You should check you printer manual for head alignment/calibration procedure...
Oct 15, 2012 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
Printer colour alignment out. How do it align this?
CALIBRATE THE PRINTER
Use the menus
1. Press OK to open the menus.
2. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the listings.
3. Press OK to select the appropriate option. An asterisk (*) appears next to the active selection.
4. Press the Back arrow ( ) button to scroll back through the submenus.
5. Press X to exit the menu without saving any changes.
Color Calibration
? Power On Calibration. Specify whether the product should calibrate when you turn it on.
? Calibration Timing. Specify how frequently the product should calibrate.
? Calibration Mode. Specify the type of calibration the product should use.
? Normal
? Full (slower)
Full calibration improves the color accuracy of photos printed on 100 x 150 mm (4 x 6 in)
HP Color Laser Photo Paper.
? Calibrate Now. Set the product to calibrate immediately.
NOTE: You must click Apply before your changes take effect.
Jul 18, 2011 | HP LaserJet CP1515n Printer
My laser plummet is loose how do I fix it
There are no less than 7 screws involved in maintaining the laser plummet alignment. Make sure the 2 on the side are snug, but not tight as it will damage the plummet and the single standard screw on top is secure as well.
The 4 hex set screws on the top of the plummet mount are for calibration. Set the instrument up on a tripod and turn the plummet on. mark the position of the laser on the floor, then turn the instrument 180 deg horizontally. if the laser is no longer in the same place i recommend getting it professionally calibrated. 6 of the 7 screws involved affect the calibration, and it is not a job for the light hearted. As well, if those screws backed out, then likely more (maybe unseen) are loose as well.
I can strip down, clean, lubricate and reassemble and calibrate one of thoes in a couple hours, but it has taken me many years to get to that point.
Jul 07, 2011 | David White DavidWhite 448879 LT8300LTULP...
CDJ 1000MK2. CDJ pitch control is out of calibration. The pitch plays at zero when the slider is at what should be the slowest setting. How do i reset zero to the middle of the slider.
There is a fine adjust on the pitch control circuit board, however if it is staying at Zero at the extremes then it's time for a new pitch control :(
Jun 25, 2011 | Pioneer CDJ-1000 CD Player
Dvd plays sometimes
If this unit had worked in the past and has started acting up without being droped, jarred, banged, or slammed around, then it may very well be as easy as dirty optics. Get a lens cleaner kit or a Q-tip with a little glass cleaner and clean off the lens of the optical transport.
If this does not work:
You will need to see what the optical transport is doing. The door needs to be opened and the switch that tells the player the door is closed needs to be tripped (usually with a paper-clip or small tool). Watch the optical transport to make sure it moves back and forth, up and down BUT DO NOT LOOK INTO THE LENS DIRECTLY as this can cause retinal damage. If it does all these things, then the motors are working properly and the issue is either in the optical alignment or the decoder chip.
If it's the optical alignment, you might be able to open the player and start changing the height of the drive placement so the laser focuses more accurately on the disc. This will require a disc with an opaque or printed side to stay in the drive while you calibrate. You can then safely look at the disc and see the red dot of the laser to determine the size of the dot. The smaller the size, the more in focus the laser is. This calibration must be done for the entire length of the oprical transport track. there are two screws that change this on either end and both muse be checked and calibrated. The optical transport has some focus adjustment capability (hence the up and down motion of the optics), but if the transport is beyond the limited capabilities of the auto focus, it needs to be brought back to correct.
May 12, 2008 | Televison & Video
Freezing video
Different discs are read with different focus ranges. Production pressed DVDs are different in thickness that recordable DVDs and CDs are also different than the afore mentioned items. Your optical transport could be out of alignment, but check to see if CDs will play first. If CDs and Production DVDs will play, it is possible that you have a dirty lens or there is something interfering with the laser (i.e. dirt).
Here are a couple of solutions:
Mar 28, 2008 | Insignia IS-PDVD10 Portable DVD Player
Pioneer CDJ-800MKII
Any error codes??? you must provide some more info... is the screen blank? When you are trying to insert a cd do you hear any noise from the mechanism?
Aug 01, 2007 | Pioneer CDJ-1000MKII CD Player
Pioneer CDJ-1000 CD Player Logo
1,113 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
