Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F1 error code
Does anyone know how to fix this? I get F1 error in the start and in the middle of the cycle, have to stand there and push cancel and start button about 15 time before it will finally start the load. Any help would be great. Thanks, Litisha
  • 20 more comments
  • kgilbert38 Jul 27, 2008
    I have the same problem. I receive a F1 error when I try to start a load of clothes.
  • labiau Jul 27, 2008
    Got the same problem, instead of cancel, we push pause. It starts after 3 times. But stops before rinsing. I beleive it is manufacture`s error, too many consumer complains. Hopefully it will be a recall on this model.
  • chumke Aug 15, 2008
    The F1 error code comes up at the start of the cycle. We have to press start 4-5 times before it clears and begins to fill with water. HELP.
  • leanneblanco Sep 23, 2008
    I have same problem - it stops & throws the error at the beginning of the wash & rinse cycles. I have to cancel & start it about 3 times before it moves forward, though the load I'm running now is on the 'whitest whites' and it doesn't seem like it wants to move pass the '30 mins remaining' point.
  • sgwizz Sep 26, 2008
    I have the same problem and it seems that with each load of laundry I do,I have to cancel and start more time - anyone have a fix for this?
  • rthoney Sep 28, 2008
    I have the same issue. It happens when I start the washer. It wont fill up. I find that if I turn it off and then turn the dial to drain&spin and start it again for a minute or two, then shut it off, turn it back to bulky items and start all over again it works.
  • nickirookert Oct 01, 2008
    I have the same problem with the F1 appearing at the beginning of washing and when the rinse cycle starts. I have to press pause/start several times to get the wash going.
  • Anonymous Oct 10, 2008
    f1 code
  • hedgehog1 Oct 22, 2008
    my Whirlppol Cabrio stops about 2 seconds after it start, and I get an F1 error code and beeping, machine is basically locked up.
  • Anonymous Jan 27, 2009
    same as described. please post a solution.
  • drayllih Jan 27, 2009
    same problem as everyone else I also just had the drain pump replaced because the machine wouldn't spin. I am really sad about this I saved up for this machine after our 25yr old one bit the dust It took us 6 months of using the laundry mat to afford the machine that isn't yet a year old from purchase and has already broke down and codes F1! Help!  From Drayllih
  • jaydee39 Jan 30, 2009
    about 2 seconds after start f1 comes up with beeping. I have to hunt for a cycle that will work.
  • nkjdonleas Jan 31, 2009
    ANy help with the F1 error?
  • mk_reach Feb 01, 2009
    I get the F1 error code and have to restart a couple of times
  • spicandspan Feb 02, 2009
    I have the same problem and you have to shut the machine off and restart several times, or change cycle direction before machine will start up again!!! Does anyone know how to fix this?
  • hlessjon190 Feb 02, 2009
    I have the same F1 problem and I am SICK OF IT> The machine is beeping at me NOW!!
  • lmartinez725 Feb 16, 2009
    I have the same F1 problem. I start the washer and it takes awhile for the lock then water starts then it goes into the F1 code and just beeps. The only thing I have done is restart and restart until it goes then some times it does it when it gets to the rinse cycle. I am tired of this!! Does anyone have a solution for this??
  • aomarvargas1 Feb 17, 2009
    F1 error code you know what i am typing about, takes for ever to whash
  • Anonymous Mar 17, 2009
    I have the F1 appearing everytime I turn on the washer. Very frustrating.
  • Anonymous Mar 18, 2009
    cabrio washer flashes f1 on startup and in the middle of the cycle
    cabrio washer flashing f1 at start up and in the middle of the cycle.
    cabrio washer flashes f1 at startup and in the middle of the cycle
I contacted whirlpool... they sent a repair man.. and they fixed the problem for FREE and sent a new computer for the machine.. they recognize there is a problem but it is not a recall
Posted on Feb 21, 2009
Did anyone find a fix for the F-1 code problem?
Posted on Oct 19, 2008
Sad to say i had this exact same problem. Decided on calling Sears for an estimate. Technician arrived just this morning and said the Main Control Board is bad. Need a new one now and he said it was #372.00!!! not happy at all... so im looking for other options to purchase the control board at a cheaper rate since my warranty is not valid any longer.
Posted on Mar 16, 2009
Possible solution involving disassembly... This worked for me hopefully it works for you.
Just wrote a step by step but could not post.. .so here's my last attempt
After a technician replaced the electronic lock, then a leak in the water pump, we got an F1 error on the Cabrio WTW6600SW0. Some research explained that the F1 problem is a Controler Unit problem. We were going to toss the washer, so with nothing to lose I performed the following steps which solved the F1 issue for me.
[Note if washer under warranty any tampering will void the warranty]
1) Turn off and unplug the washer.
2) Remove the Control Panel housing assembly
(Control Panel parts 9 and 14 of the below link
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208181164.pdf).
Try not to touch any of the electronic components, since you can give it a static shock that can destroy the electonics.
3) Locate the clear tube on the right side facing the washer and unplug the tube from the Control Unit (you can handle the plastic but avoid touching the electrical parts). Did not see it in the above link but closest to plug #21 (Harness, Thermistor). I believe this is a water control leveler that uses air pressure to signal the height of the water level.
4) **** the air out of the tube and squeeze the tube to trap the air suction. You do not have to turn blue sucking the air out just a little, also you do not have to squeeze the very edge of the tube. A couple of inches away from the end will do.
5) Replace the tube without letting out the air suction.
6) Reassembly the Control Panel housing assembly.
After doing this I had no more F1 error.
Good luck
robrosa99
Posted on Feb 17, 2009
    Problem Solver:
  • 4 Answers
Http://www.petitiononline.com/cabrio08/petition.html
Posted on Aug 07, 2008
I turned on my self cleaner oven this morning and it started beeping and flashing F1. The only way I could stop it was to push the cancel button which of course turned it off
Good Morning Monica, thank you for your post!
Based off what you have described your Frigidaire range is providing you with an error code of F1 after you started a self-cleaning. The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the F1 error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Dec 06, 2015 | Frigidaire Kitchen Ranges
Kenmore Oasis Elite Model #110.27086601. When I push start, a F1 code will appear. Then I will push stop and then start again. Sometimes I need to do this two or three times for the washer to start. ...
Hi Sandra:
You have a bad control board, the F1 is the error for the bad board; what you need to do is remove the three screws at the back of the control panel and tilt the panel forward. The main control card is there. Unplug and re-seat all the connectors. Reassemble the unit and try it. If you still get the F1 error code then the controll card is toast.
What happens is these connections come loose. If they arc acrost the contacts then that is what fries the board. Most people that know about this fix are lucky and the unit starts to work right again. Some arnt so lucky.
If you are one of the lucky ones place a healthy dab or two of hot melt glue stick on each connector to hold them from working loose again.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 10, 2011 | Kenmore Washing Machines
F1 error appears just right after I turned the machine.. I had to stop and tstart 3-4 times before it gets on to cycle. Then at 23 minutes F! error error comes back and I had to do the same thing (stop and...
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 28, 2011 | Kenmore Washing Machines
Hlmy whirlpool is electric and we were trying to set it to clean the oven but it comes up with a f1 and then startes to beep but win't start cleaning process what does that mean?
Aug 24, 2011 | Whirlpool 30" Free Standing Electric Range...
My stove is coming up with a code F-1 what does that mean??? jo garrett
Gene
Aug 05, 2011 | Whirlpool 30" Free Standing Electric Range...
I hit cancel in the middle of a cycle and now it keeps saying F1
From the maytag website:
To remove the error display, press Power/Cancel or Pause/Cancel twice.
If Power/Cancel or Pause/Cancel does not work:
Unplug washer or disconnect power for one minute.
Plug in washer or reconnect power.
Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, call for service.
Sep 24, 2009 | Maytag EPIC MFW9700S Front Load Washer
F1 error code
The F1 error code indicates a primary control failure or pressure signal out of range. Once the pressure hose & air dome have passed testing, the control board will need replaced. Good Luck And Please Rate FixYa!
Dec 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
486 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
