Question about Continental CE75106 Portable Air Conditioner
My unit blows cool for a few minutes and then blows hot. How can I fix it?
Is there a way to open the unit myself and try to fix it?
  • rurin Jul 25, 2008
    There are screws on the back of the unit. Do these units have a liquid coolant that would need to be replenished, like freon; or might it just need a good cleaning? Thank you for your help.
  • B Carson May 11, 2010
    As a repairman of thirty some years, I expect there is a way to open an air conditioner and try to fix it. I always start by taking out some screws. Can you see screws that would open some covers?
  • 143 Answers
The liquid coolant is not supposed to be replenished. It is supposed to be sealed inside metal at all times and temperatures.
If it has escaped, you will need a brazing torch, a set of pressure gauges, a container of new freon, a license to buy the freon, a vacuum pump, some fittings to attach the gauges to the pipes, the ability to measure the quantity of freon accurately, and some education so you can avoid hurting yourself with molten metal, liquids at 40 degrees below zero, and pressures in hundreds of pounds per square inch. The tools cost nearly a thousand dollars. The license and education, I don't know the price. At least several hundred more.
Unfortunately, a short burst of cooling followed by poor performance is usually caused by the freon having partially leaked out.
The best you can hope for is an electrical problem. Those are cheaper and easier to repair, if you have voltage and amperage meters and know how to use them.
Posted on Jul 25, 2008
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Window air conditioner cools (very icy cool air) for a minute or two then switches to fan. Will then stay on fan for about 10 minutes and then once again get "very cold", but only for a minute or two
Before I even read that far into your post, I was thinking "thermostat" replace it...It seems to be failing badly. If you take it into logical perspective...normally the unit gets turned on, then takes a bit to get cold, then once it reaches its pre-determined temperature, turns the unit either "off" or just blows the fan...by kicking off the compressor. This unit you have is getting this cycle done within 5 minutes instead of a few hours...replace the thermo and you should be fine. Now if you could post the exact model number here I can go look up the part for you.
Jun 20, 2012 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
Hot air blows but cools down in 15-20 seconds.
You likely have a restriction in the heater coolant hose circuit - perhaps a coolant control valve not fully opening, or a kinked hose.
Insufficient coolant volume is flowing to keep the heater core hot.
Try back flushing the heater core system with a garden hose to check flow.
Nov 13, 2009 | 2003 Audi A4 Cabriolet
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Continental CE75106 Portable Air Conditioner Logo
153 people viewed this question
Top Continental Heating & Cooling Experts
Tim Whalen
Fotis Papastamatiou
jasbo
jasbo
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
