I have a LP gas log heater, the thermostat is in the living room and I would like to shut this room off this winter. Is it possible to add a second thermostat elsewhere in the house so this can be done?
  • 143 Answers
Yes. If the thermostat is connected with electrical wires you can buy some wire and move the thermostat or add a second thermostat. Just be aware that dual thermostats can cause people to forget that they have to shut both of them off to stop the heater.
Posted on Jul 25, 2008
Reznor UDAP-100 heater miss fires when shouting down and turning on.
check gas pressure coming in to unit or burner tubes dirty if dirty the boom means gas is pooling then lighting unsafe clean out and check gas pressure
Apr 15, 2017 | Reznor UDAP Series -100k BTU High...
Bought a used lp gas heater stove for living room.need istructions with pictures on how to install the vent. did not come with a manuel and unable to find info needed on website. this is an Empire Cast...
You have this posted under the Z-vent heading... is that the make pipe that came with the stove, and if not, what vent pipe came with the stove... we need to know which pipe it is exactly to be able to help you best...
heatman101
Aug 29, 2011 | Flex Z-flex Vent Pipe For Gas & Lp...
My white rodgers control panel is set on vacation (green light) is on. I have held down the arrow buttons to get it off of vacation mode but it is not working. Obviously i need to switch it off as we have...
Water heater and gas valve are not clear:
Add a comment with description of water heater and gas valve for possible help.
Open following link for White Rodgers intelli-vent gas valve thermostat:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
1) Typical instructions for Kenmore and AO Smith water heater with Intelli-vent say:
Set on-off switch to ON position.
Hold down both arrow buttons for 1 second.
Then press hotter button.
2) Also check that 120Volt electrical outlet has power, and check outlet with cheap circuit analyzer from home center.
3) If Intelli-vent gas valve thermostat is malfunctioning, and won't reset, then contact manufacturer of water heater for replacement gas valve.
Label on side of tank will have Model number, manufacturer, type of gas LP NG, serial number for part ordering.
Add a comment for more help.
Jun 10, 2011 | White Rodgers Water Heaters
Hi. I have a Cozy CDV255B wall-mount heater. The burner stopped working suddenly. The pilot is on. I jumped the two wires connected to thermostat and that did not help. Then I replaced the thermostat and...
Did someone possibly turn the control knob from ON position to the Pilot Position. If that's the case, the burner won't come on.
Another thing that might cause your problem is low gas pressure. If you have LP Gas, the regulator on the gas tank may be frozen or the tank may be almost empty.. This happens frequently when temperatures remain well below freezing. To test this theory, soak a bath towel in hot water, ring it out and quickly place it around the LP tank's regulator. This will thaw the regulator and allow gas to flow smoothly to your heater. Remove the wet towel from the regulator once it has thawed.
If the freezing continues to occur, wrap insulation around and inside the bonnet of the tank. You may also want to contact your propane provider about this. As they may need to add some ethanol to your tank.
Jan 27, 2011 | Cozy Heating & Cooling
How do you start the heater for the first time in the spring?I don't know where to begin. The pool pump is on and working.
Make sure all gas is on to the heater and the gas valve inside the heater. Be sure all winterize plugs are in place and tight then make sure all valves are letting flow to the heater. If the heater won't start at this point be sure you have enough gas if it is LP. You need at least 30% in the tanks to get the heater to fire. Then you will have a shut off valve just outside the heater. Shut this off and you will fine a union near this, crack the union open and turn the gas back on for a few seconds till you smell gas then shut off and tighten the union back up. let it sit for 15 or 20 min. to let the gas clear then try again. If it still won't start it may be time for a repairman. I hope this helps, good luck.
Apr 18, 2010 | Sta Rite Sr200lp Max E Therm Pool & Spa...
How do you shut down
the pilot light always stays on, its designed to allow your heater to turn on by itself without you needing to light a match every time. if the pilot light is burning you have nothing to worry about. its when the pilot light goes out that a small amount of gas leaks into the room. and by small i mean smaller than a hand held lighter... if you still want to shut the entire thing down you could turn off the gas line feeding the heater or possibly the whole house, otherwise the pilot light will stay on. as far as the actual heater turning off, thats probably controlled by some sort of thermostat somewhere. if you set the temp to very cold it should stay off. if that doesn't work then you may need a new thermostat.
Dec 31, 2009 | Vanguard International VN18B Infra-Red...
Our heater seems to have therostat set low. We are cold.
not sure if this unit has any type of sensor to protect you from carbon monoxide but if it is ventless and operates on gas it may be tripping on sensor any ventless unit must be operated with fresh air for combustion
Apr 06, 2009 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
My new RHFE-1004FA has a slight whistle to it.
May have a bad regulator on the tank or bad gas pressure. The colder it is, the less gas pressure you get out of the tank.
Nov 23, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Gas furnace cycles on then shuts down
COULD BE A ROLL OUT SWITCH ,OR GAS PRESURE TO HIGH TRIPPING ROLLOUT SWITCH COULD BE A FLAME SENSOR ,TELL ME MORE IF POSSIBLE
Nov 21, 2008 | Water Heaters
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
