22 inch monitor
I have a 22 inch monitor and can not get the display to fit in its entirety on the screen. I am still having to scroll right in order to read everything.
  • 558 Answers
Screen resolution is not correct. highest is not always correct setting so decrease the setting until you can see all the image.
hope this helps don't forget to rate me if it leads to to a solution.
Posted on Jul 22, 2008
I do not know how it happened, but the display on my widescreen monitor is now about an inch smaller on the left and right side. The display is now square. How can I fix that? I am not sure of the exact...
The resolution of the desktop has been changed. Go to Start , Control Panel, Display, Properties and from there change it to the correct one - it's listed as the default resolution in the user manual of your monitor. If you don't have the manual just try all the resolutions available until you find one that fits and looks well.
Jul 30, 2011 | LG 22" FLATRON LCD Monitor
How do I fit the desktop to the full screen of the monitor?
before you change your screen resolution, you should know first the dimension of your monitor..
this is the common screen resolution for 22 inch LCD monitor: 1600 x 1024 1920 x 1080 up to 3840 x 2400
Note: You can only use this resolution if your video card supports this given screen resolutions. You can set your resolution through configuring the display setup.
May 26, 2011 | Emprex LM2201 22" LCD Monitor
The screen went blank
Have you check all connection to see if they are right, check if no cable was unplug, if you have and yet no picture display, It could be that the picture board on your monitor has started malfunctioning, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 07, 2010 | LG L226WTQ-BF 22 inch Monitor
Display on AcerX223W now has side margins and does't fit screen
i think you need to format
i hope i can solve your problem
Aug 26, 2009 | Acer 22" X223w LCD Monitor
My screen is x X y inches. The windows page doesnt fit into it. There is one inch of black space on the monitor on the left and one inch of my windows screen is lost on the right!!!!!!!
With the on-screen controls, select Auto-Adjust. This should set suitable defaults based on the incoming signal. If you are using the VGA connector and the position still needs to be adjusted, use the on-screen controls to shift the displayed image to the proper location (under Display Settings -> Horizontal Position).
Apr 17, 2009 | Dell UltraSharp 1908WFP 19inch Black...
Wallpaper won't stretch to fit 22 in monitor --
You need to adjust the width on the monitor itself using the menu button on the monitor.
Dec 30, 2008 | AOC Monitor
Windows XP not fitting full on 22 inch computer screen
Your new monitor will show a "native resolution". In the instructions below, try that setting first. If that fails try other settings.
- Right-click on an empty spot on your desktop
- Chose "Properties" on the menu that appears
- Click the "Settings" tab (at the top right)
- Move the "screen resolution" slider to a different number
- Click "apply"
- See how you like it
- Repeat until you get a setting you like.
Dec 27, 2008 | Computers & Internet
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Syncmaster 245bw monitor resolution screen and resolution issues
These two devices are not compatible, you may need to read the information on this LCD MONITOR to see if the resolutions are compatible, this often times happen when monitors are purchased!
Nov 25, 2007 | Samsung SyncMaster 245BW Monitor
Computers & Internet Logo
409 people viewed this question
David Payne
David Payne
