Peg Perego Vespa Scooter Logo
Posted on Feb 08, 2011
1963 allstate 125 scooter will run like new than it won,t start even thought it's getting spark and gas
Anonymous
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Mar 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
13574
Points
65
Hi! I assume your problem only applies when the engine is hot. This could be one of several things:
1 - bad seals 2 - broken engine body (heat expands it and lets air in / compression out) 3 - related to above, but happening on top end (cylinder/head)
All these are hard to fix at home, but there it could also be related to a carb problem... imagine your scooter is running too rich, it will run ok for the first kms, but after you stop and because the plug is dirty and/or the engine is flooded, it wont start anymore.
When this happened did you check the sparkplug look (is it dark? dry or oily?)
Hope this helps! Regards
125cc scooter no spark
you need a new coil !
Nov 20, 2013 • Motorcycles
Carburetor cleaning
check air filter . remove filter run scooter see if that fixes problem . if it does buy new air filter
Buddy 125 will not start
ENGINE/CARB CLOGED TAKE SPARK PLUG OUT AND AIR FILTER OFF COVER INLET TO AIR FILTER WITH HAND AND SPARK HOLE WITH THUMB CRATE GOOD SEALS CUP UN CUP REPEAT UNTIL HEAR A POP SOUND.
Scooter won't start with electric start or kick start.
  1. Try depressing the brake handle when starting.
  2. The battery has not been charged.
  3. The battery is hooked up wrong. This is often the reason for blown fuses.
  4. There isn't enough gas or two-stroke oil in the scooter.
  5. There is a gas flow problem, especially on the Euro Scooter or Yamaha models.
  6. The spark plug wire is not connected.
  7. A low battery or bad relay can cause the scooter to only start by using the kick starter.
  8. There is no spark to the spark plug. The coil is bad and needs to be replaced.
  9. Turn the key to the "on" position.
You need to check for a spark. There are a few ways to do this. The easiest way is to remove the spark plug and put it back in the spark plug cap. Then ground it to the engine - you should be able to lay it against a non-painted portion of the engine. Make sure there is good metal-to-metal contact. In a semi darkened area, attempt to start the scooter. You should see a definite spark at the tip of the spark plug. It's hard to see in direct light. If the color of the spark is blue, that means it's a strong spark. A white color is less strong, and a yellow color is weak. Most scooter starting systems are a bit weak (compared to cars). Even a yellow spark should start your scooter just fine.
The spark must occur at the right time. Just about all scooters made since around 1980 have an electronic ignition. These systems can rarely be set. In general, the spark occurs just before the piston reaches the top of it's stroke. There is a slight delay between the spark plug fire and the fuel-air mixture ignition. That's why the spark occurs a little early. Most ignition systems have an advance unit build in. As the engine speeds up, the time of the spark retards a little bit. This helps the engine fire the mixture at the proper time
There are a lot of tiny fuel and air passageways in the carburetor that must be kept clean it order for your scooter to run right. Carefully, take the carburetor apart. This can be relative easy (on a 50cc scooter). The carb has tiny passages that can get gummed up. Your scooter will not run correctly if the carburetor isn't completely clean, so take your time. I use a gallon container of carb dip (you can get a gallon at your local auto supply store).
First, remove all of the rubber and gaskets or they will get damaged. After a 20 minute soaking in carb dip, I blow out the carb with compressed air. You have to get all the jets and the passageways clean. Be sure the jets are clear, especially the starter jet. Sometimes carb cleaner won't clear out these tiny jets. Use a guitar or a piano string, a strand of copper electrical wire, or a tiny drill bit pin vise. Be sure not to increase the size of the hole in the starter jet or you'll change the tuning. Carefully reassemble everything, checking for cracks in the rubber carb boots and the gaskets. Replace them if they are old and cracked. Be sure and remove all rubber and gasket material first or they could get ruined. Spray carb cleaner also works if you're diligent.
If you have an electric choke, check it to make sure it works. Check the resistance between the wires - you should see around 10 ohms or less. Measure the length of the choke assembly. Remove the choke from the carb and plug the wires into a 12V source for 15 minutes. The choke body should be warm. Measure the length again - it should increase by around 1/8".
Next, consider whether your exhaust pipe is clogged. This is especially a problem with older two stroke scooters. The unburned fuel/oil mixture builds up in the exhaust pipe along with carbon over time. If the exhaust pipe is clogged, your scooter will run terribly or not at all. It can be difficult to tell if the exhaust pipe is clogged. The easiest way to tell is to remove it and try starting your scooter. It will be a bit loud - two strokes will sound like a chain saw. If it runs with the exhaust pipe off, you know that is the problem
hope this helps
John
2helpful
2answers
My scooter wont start can u help
It is definitely frustrating when you can't get your scooter or moped started. The first thing you'll need to do is to narrow down the problem. In order for your gas scooter to start, it really only needs 3 things:
1.
Your scooter needs to spark at the correct time.
2.
Your engine needs the proper fuel/air mixture and exhaust flow.
3.
You need sufficient engine compression.
Top 9 Reasons Why Your Scooter Won't Start:
1.
Starter problem
try changing the air and fuel filters; spark plug(s) as well.
Top Peg Perego Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
