Question about Broksonic CTGV-5463TCT TV
TV cuts off
My Broksonic TV cuts off every 75 seconds. It is 3 months old and the
picture tube is strong with good color.
I am on satalite but even with that off it still cuts off.
  • captasdf Jul 22, 2008
    I will give this a try tomorrow after I buy a can of compressed air. I will let you know.
  • 4,889 Answers
I would look at either the on/off button faulty or a heat sink not doing it's job.
Either way, the solution is quite simple. The on/off button simply toggles a low voltage circuit that powers your tv. If it is dusty, it may complete the electrical circuit and send a false signal.
A heat sink may be dusty and unable to dissipate heat. Overtemp protection may be switching the TV off.
I would take a can of compressed air, open the back and clean the dust off the circuit boards.
Posted on Jul 22, 2008
    Brigadier General:
  • 6,966 Answers
Offhand, initial suspects could be:
  1. power supply;
  2. cold solder or loose connection (heat related);
  3. internal protection circuitry kicking in.
A couple of question pls:
  1. any burning smell or crackling sound;
  2. was there any power surge or interruption prior to the problem;
  3. anything out of the ordinary;
  4. during the the 75 seconds that it is on, picture and sound normal?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 22, 2008
    Hi again,
    This is a repost of my response to your "Ask Me" posting here.
    Repairs of course would require familiarity with electronic circuitry
    and components, use of a DM and a soldering iron and access to to a
    service manual or at the very least a schematic diagram with voltage
    Assuming the above and you are considering a DIY (do-it-yourself),
    perhaps the easiest and fastest would be to do a shotgun approach, i.e.
    open the unit and re-solder most of the solder joints with particular
    attention to the power components such as resistors, transistor, ICs,
    transformer (including the FBT). Of course one can never be sure which
    really is defective but the objective is to repair with no in depth
    diagnosis. Another component type to check would be the big capacitors
    right after the diode(s). Look for any visual indication of
    bulging/blistered, leaky or anything out of the ordinary among the
    power capacitors (and even the other components), if found/yes, then
    replacement(s) would be needed.
    Other than the above, further diagnosis requires that you operate the
    unit with the back cover off and determine if it is heat related. This
    could be done by powering the unit, wait the 75 seconds, quickly unplug
    and feel for any component that heated up. There might be a different
    smell to it also. Of course safety precautions when working with live
    sets and/or units just unplugged must be observed.
Broksonic 19 inch CCVG 1935 - no sound, no picture, just a blue screen
Blue screen means either no signal (if unit has rear connections hook a DVD etc to one and go to that input and see if it works) Or the blue may mean set is in shutdown----5 months old and it should still have a warranty?
Apr 23, 2012 | Broksonic CCVG1935 19 in. LCD TV
Magnet came in contact blue green and red color
Every time you turn on a color TV, a degaussing circuit tries to neutralize magnetic fields on the picture tube face that can cause distorted colors. That degaussing circuit isn't strong enough to clear up the field left by direct contact with a magnet. You need an external degaussing ring to clear up the funny colors. You can see what one looks like here. You might be able to find one for sale on eBay or borrow one from someone in the TV service business. Or you can take the TV to a shop where they can degauss it for you for a small charge. Just be aware there's a chance the picture tube may have been damaged if the magnet was very strong and was in contact with the tube for any length of time. A thin metal screen called the shadow mask is behind the tube face, and if that was warped by the magnet then the colors will never line up correctly again. If this has happened, even after degaussing the colors will still be wrong. But you won't know until you try. Good luck, and thanks for using Fixya!
Jun 02, 2011 | Daewoo DTQ-27S5FC 27" TV
The red power standby light is on. Turn on the TV , it turns green for about 15-20 seconds then turns red again. No picture, sound, or able to bring up menu. Have tried depressing the reset button on...
Hello repairdud304,
This is a common problem with Broksonic LCD televisions. (If you want to look them up you can search by their manufacturer Orion.) The problem lays within the power supply and a uneven voltage processor. This happens for no reason sometimes, but what acutaly happens is that a chip controls the amount of voltage coming into the tube. This chip has malfunctioned and works for about 15-20 seconds before resetting. This needs to be replaced. It can be costly. I'll leave you with some links that may help you in your voyage into Television Repair Land. Good Luck!!
Broksonic Manual(s) - Includes Troubleshooting Section
LCD TV Repair Specialists - Near you!
LCD TV Parts - Google Suggested!
I hope this solution helps you!
A Pleasure,
Guide - Vexed Demon
P.S. If you feel this answer to your question was great. Please take the time out to review me and give me a great rating! I am trying to level up and become a premium member to help others like yourself! The only way I can do this is by your ratings! Thank you for your time in advance.
Jan 13, 2011 | Broksonic CCVG-3276 32 in. LCD TV
We have an old TVwhose picture cuts out every 5mins or so
Not a picture tube problem. Re tune the the TV by auto search or manual tuning.
Store your favorites later in your way.
May 03, 2010 | Televison & Video
12 yr. old 25" G.E. picture fading
I gotta love it when people make up answers. There is no such thing as a "contrass module". I'm assuming the poster meant "contrast". The trouble is your 12-year-old picture tube. It's gotten weak and isn't getting as bright or sharp as it used to. Picture tube manufacturers estimate the useful life of a tube at about 7 years today. There are adjustments inside that might help some, but you need a new picture tube. It's going to cost a lot more than $60 to $75 for that. You're better off replacing the TV.
Apr 22, 2009 | GE 25GT240 25" TV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
No color - tv only
It may be your color tube going out. It has happened to me several times!!!!
Jun 25, 2008 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
Sony Rear Projection TV - Red tube too strong
remove the front speaker assembly and the small access panel behind it and you will see a small square control assembly with 6 dials on it 3 control the color guns and 3 control the 3 gun focus. Try turning down the red control slightly they will be set up just like the CRTs red green and blue.
May 16, 2008 | Sony KP-57WS500 57" Rear Projection...
Red picture
Assuming this is a TV with a picture tube and not plasma or LCD; I'm afraid that your picture tube is dying on you one electron gun at a time. From what you said your green electron gun is almost totally dead and the two remaining blue & green guns aren't far behind. Eventually you'll have no picture at all and I would estimate that to be about 6 more months but whatever the time eventually it will go totally black. These blackout periods will get longer and longer. The only way to fix your problem is a new picture tube but my will probably find it less expensive to just get a brand new TV set.
Apr 14, 2008 | Toshiba 36A50 36" TV
Color is not good around outer edges of picture
When the colors are off around the edges on a regular picture tube TV, it usually means that the degaussing thermistor's solder joints have cracked loose. Another possible cause is that a strong magnet, such as in a stereo speaker, was brought very close to the picture tube and has magnetized the tube. Resoldering the solder joints on the degaussing thermistor and demagnetizing the picture tube should put the color back to normal.
Aug 17, 2007 | Toshiba 32AF45 32" TV
Broksonic CTGV-5463TCT TV Logo
82 people viewed this question
Top Broksonic Televison & Video Experts
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
