Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Wireless card there is a swich on my laptop that turns the wireless card on and off, i have never used it but when leaving a friends i accedently turned it off when packing it up now it well not turn back on. is there a way to fix it or replace it if needed?
    Genius:
  • 2,028 Answers
Go into the wireless configuration and see if the radio is enabled. The switch is for manually enabling and disabling the radio, if the radio has been disabled in the configuration then the switch will not work. The other thing you can do is, uninstall the wireless drivers from the device manager and reboot. The machine will find the wireless and reinstall the drivers. This should get it back up and running. NOTE- the radio is the terminology used for the wireless receiver, since the wireless card works on frequency it is considered a radio.
Posted on Jul 22, 2008
How do i turn on wireless
i don't know about dells set up But normally on the front panel there should be a slide swich to turn on the wireless connection if this fails contact dell
Feb 09, 2013 | Dell Inspiron 1721 Notebook
I keep losing my wifi connection
try reseating the wireless card or airport card. if that doesnt work. turn off your wireless router and your macbook. leave off for 10 mins then turn on the router first then macbook. try to connect and see if that fixes the problem.
Dec 19, 2012 | Apple MacBook Air
Wireless switch is broken cannot turn on wireless adapter
Dear Friend,
If the wireless switch broke, you might need a flash light and something very thin and long to turn it back on. Now, if the switch attached to the motherboard broke as well you need to think about getting another motherboard.
You might want to consider and external USB or PCDM wireless card if you cannot turn it on.
Good Luck!
Jan 02, 2012 | Acer Extensa 5620 Notebook PC
How to swich on wireless on windows vista
The easiest way to turn on wireless if you are on a laptop in Windows Vista:
1. Go to Start> Type Windows Mobility in Search Box.
2. When the results come up: Under Programs, you will see Windows Mobility Center.
3. Click on it to open Windows Mobility Center.
4. If the wireless is off : it will say "turn wireless on"
5. Click on the button to turn wireless on.
Apr 25, 2011 | Computers & Internet
Can someone help mee?? I just got a used laptop
Hi! some laptop have a built in wireless network card.. some dont have.. check first if the laptop have a built-in wireless nic. if there is one.. some of this wireless nic use the built in software so that you can connect wirelessly. you can just turn off that software and use the windows xp wireless zero config.. to turn on the windows xp wireless zero config, sometimes there is an option if you turn of the software for the wireless nic but if there is no option, you can click on start and then select run and from the box, type services.msc and it will show you all the services for the computer and scroll down to the button and you will see wireless zero config and its off or disable just right click and it will give you the option and enable it.. this will connect you wirelessly without any problem..
Jul 12, 2009 | Belkin (F5D5231-4) Router
Internet wireless card
It's possible that the wireless driver is not installed or the wireless card is turned off in the bios or defective.
1. Check if the the driver is installed. Go to start. Right click 'My computer'. Left click properties. click hardware. click device manager. If there is a red 'X' on the wireless driver. Right click it and click enable. If there is a question mark on network controller or wireless driver. Click this link and choose the model of your laptop to get the wireless driver. Run the file to install the driver. Restart the computer if instructed then see if it worked.
2. If the light still wont turn on, go to the bios. You can do this by turning the computer off. Turn it on and repeatedly tap F2 right after pressing the power button. You should get a screen where you can change the settings. Click this link and choose your laptop's model and look for the instructions on how to turn on the wireless card in the bios. You may also browse the BIOS screen for that setting. Once you've set it to on, save the changes and restart the computer.
May 04, 2009 | Sony VAIO Notebook
Toshiba 1153's1552 wireless
look in hardware devices.in the list which comes up look in network devices or underneath the laptop should be a removable panel (1 screw)underthis you will see a board with 2 wires on it the wires are held down with silver press stud.hope this helps.p.s.is there a button on the laptop to switch wireless on and off?
Jan 25, 2009 | Toshiba Satellite 1135-S155 Notebook
Broadband speed slower with intel pro 2200bg wireless
Is it getting any better if you move closer to the router?
First try to update the driver and see if it works better, if not than there's not really much you can do with it. You can swich to cat5e cable, that will be more than enough, or if you really need wireles speed than consider changeing the wirelesscacd in your laptop.
I suggest you some atheros chip based card, because their signal strength and sensitivity is very good. First figure out what you have, open up the small backpanel of your laptop, if there's two than it could be the bigger one. The card could be Mini PCI or mini PCI-E wichever is similar to your card is the type that you need.
After that go to ebay and search for "atheros mini pci" or "mini pci-e atheros", see description for compatibility, or ask the seller if you are not certain. Delivery usually takes about up to 5 bisness days.
Depanding of the card's exact chip you can download driver from here.
Just check before ordering if there's a driver or not for your OS, because as you can see they don't have drivers for some older chips if you have a relatively new windows like Vista or if the chipset is new in some cases there's no driver for XP
But for most cards there's a working dirver and it really makes a diference after most cards.
To swich the card:
-Download the driver for the new card.
-Uninstall the current wireless driver in windows and shut down the computer.
-Swich the wireless card for the new one.
-Start the system and install the driver.
-Enjoy your new card.
Nov 23, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Donsen't boot
TRY AND RESTORE YOUR LAPTOP USING THE RESTORATION DISC THAT CAME WITH YOUR PC
Jan 24, 2008 | Acer TravelMate 290 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
138 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
