Question about Whirlpool Calypso GVW9959K Top Load Washer
CALYPSO WASHER CLOTHES GET STUCK UNDER AGITATOR. CN THE GASKET BE REPLACED AND COULD IT BE THE SOURCE OF THE PROBLEM. HAVE HAD THE RUN OF PROBLEMS DESCRIBED BUT HAVE FIXED THEM MYSELF TO KEEP UNIT RUNNING.
    Genius:
  • 1,028 Answers
On calypso the wash plate has a rubber seal around outside edge it can become distorted and have gaps ..replace entire plate gasket not separate and if you haven't already ckd the leveler/universal that moves the plateif has original it may be wearing and while you have it apart might be good idea to change it to head off future problems
Posted on Jul 23, 2008
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Blanket stuck in washer
is it under the agitator if so theres a screw inside the cap and that will usally get that agitator out
Jun 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Stops in the middle of rinsing...leaves some water at bottom-
Calypso...The pumps fail often. They have redisigned one that theres not as many problems with, but if you still have the original, this is deffinatly the problem. As far as clothes getting stuck, the U-Joints wear out and cause too much play allowing things to get stuck. Total for this repair parts + labor will usually run about 500-600. There was a class action lawsuit for this machine and they no longer make it.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
Clothes stuck under agitator pan
You'll need to remove the agitator.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 08, 2009 | Washing Machines
Calypso top loader, clothes getting stuck under the gasket
I would recommend replacing the main (outer) wash plate. Sometimes the edges of the plate become worn with age and can catch on clothing. The following link explains how:
http://www.fixya.com/support/r1065026-calypso_nunater_removal
You may not have to use all the steps mentioned, but it will give the advice necessary to complete any repairs you may require. The link also mentions where you may obtain parts. I hope you find this helpful. If you still experience problems, please post back and let me know.
Sep 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959KL1 ruins clothes
I can assure you this IS a common problem. I can't tell you how many customers I have had in the past that complained about their Calypso's leaving the same marks on their clothing. The problem occurs because of the suction on the clothes as the washer extracts water from them during the final nunator cycle. The nunator is the wash plate that the clothes get caught in. The manufacturer's cure for this problem was to come up with a modified control board that reduces the final nunator time and minimizes the suction action on your clothing. The replacement control board part number is 8571359. I have ordered and installed this board on a few Calypso's. I'm surprised that nobody advised you of this in the past. If you call Whirpool back and they deny this, I got this information from them. It may be worth your while to contact them again to see if there is a recall on this and if they would cover the cost of the repairs.
Aug 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Cloths under the agitator
There was a noted problem with the Calypso washing machine involving the control board. The machine had a tendency at the end of the wash cycle to pull such a vacuum to remove excess water from the clothes that it would pull clothes under the nunator (wash plate). This cycle consisted of a 30 second drain that often pulled such a vacuum that clothing would sometimes become stuck. The manufacturer came out with a replacement control board that took the 30 second nunator cycle and reduced it to (I believe) 10 seconds. This was supposed to minimize the possibility of clothing damage. The part number for the new control board was 8571359. There should have been a service flash out on this, but I'm not certain. You can try to get in touch with Sears at 1-800-252-1698 to inquire about this. I don't know if the manufacturer will cover the cost of replacement, but they SHOULD. This was a KNOWN problem, so they should be familiar with the circumstances. Let me know if you decide to pursue it and see what they may have to say. I hope this has been helpful to you.
May 31, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes getting sucked under agitator
I was able to find information on another web site with a Whirlpool Calypso repair manual: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Check out steps 5 and 6 on page 36:
6. Using two (2) flat bladed screwdrivers, 90°
apart, in the notches provided, separate the
dome from the outer wash plate. (Fig. 3-11)
7. Remove the six (6) 3/8” bolts securing the
outer wash plate to the universal joint.
(Fig. 3-12) Remove the outer wash plate
from the basket.
That gave me enough room to lift the outer wash plate and remove three napkins and a wash rag.
P.S. Take precautions to keep the bolts from dropping under the outer wash plate.
Dec 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washer pulling clothes under agitator
The gap between the wash plate and inner basket has widened.
Part #WP285903 retail $65.75
Nov 05, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso
Have you checked the agitator? There may be sharp edges on the agitator blades. OR the towels may be getting stuck under the agitator and tub bottom. The agitator is supposed to suck the clothing down in the center and forcibly throw the clothing outwards against the tub. The cycle then repeats.
Sep 09, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
366 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
