Question about HP PhotoSmart InkJet Printer
Unplugged from wall socket before i turned it off...now won't print
I unplugged the printer from the wall socket before I turned it off. now I am getting a "Ink" failer..and a message that said I should not of done that!!!
I have tried turning it off and on...and off at the wall socket, but it's still giving me an error mesage!
  • 56 Answers
Plug it in 100 times and cut the cord
Posted on Dec 20, 2008
How to Remove a Stuck Document That Won\'t Delete from a Windows PC Printer Queue?
Unplug printer from wall. Reboot computer. Check that document is gone before plugging printer back in. NOTE, "unplug from wall" does not mean "turn printer off". Unplug it.
Oct 20, 2016 | Computers & Internet
HP printer won't print
Hi Kathy,
What is the printer model ? Try the step below.
While the printer has power, Disconnect the power cable from back of the printer. Wait for 10 seconds and reconnect. This should fix the issue.
If this does not, try changing the wall socket. If you have connected it to Surge protector, Try connecting to Wall outlet directly.
Hope this will fix the issue.
Regards,
Sean
Aug 10, 2012 | Office Equipment & Supplies
Good morning, i was printing and the printer shut
Try to unplug the power adapter from the printer. Unplug the power cord from the power outlet in the wall. Replug the power cord after at least 10 seconds - bypass any power surge devices or power strips. Replug the power adapter into the printer. Your printer should automatically power on, otherwise, press the power button. If the printer still won't power on, please contact Lexmark technical support for additional assistance.
May 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
Getting error message "Cartridge error"
Hello
Try removing the cartridge and very carefully use a damp paper towel to gently clean the printer head of the cartridge. Do you get any ink when you do this? If you do, try putting the cartridge carefully back into place. Check the socket where the cartridge goes when you do this. Does everything seem to be in order?
Do a power reset (turn the printer off with the off button, unplug it for a full minute, then plug it back into the wall socket.) turn the printer back on.
hope this helps
Jan 27, 2011 | HP Officejet 5610 All-In-One InkJet...
When printer is turned on, Printer light turns red
1. clear all print jobs in the print queue.
2. Unplug the printer from the AC ( wall socket) wait 1 minute. Plug it back in.
I would also shut down the PC and do a clean boot.
Apr 20, 2010 | Samsung CLP 300 Laser Printer
Canon PIXMA MX860 using an Apple iMAC. Working fine until it started giving a message DPI at 300/300 and now it won't even print.
First, start with power cycling the printer. Turn off the printer, unplug the power cord from the wall socket for 10 minutes, then plug it back in.
If same problem occur, uninstall and then re-install the printer driver.
Apr 07, 2010 | Canon Office Equipment & Supplies
Printer won't start
1. completely unplug power cord from wall socket,
2. unplug power cord from printer
3. unplug printer cable completely from computer
4. unplug printer cable completely from printer.
5. let printer stay disconnected for approx 1 minute
Now securely:
1. reconnect the printer cable to the printer.
2. reconnect the printer cable to the computer
3. reconnect the power cord to the printer
4. reconnect the power cord to the wall socket
turn printer on
You may find that a connection has simply worked itself loose over time.
Mar 29, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
HP Deskjet F300 All-in-One series. Had been printing well,and then just stopped when half way thru a page. I turned it off for a couple of minutes,then on again, it finished printing the page, and will now...
Hello ,
We will start with a reset . Pull out the power cable from both ends.Let the cable stay isolated for 20 seconds . Then follow the steps below -
a. put the power cable to the wall socket first
b. press and hold the power and paper type button together and insert the power cable ...... do not release the buttons till all the light flash together - leave the buttons.
c. let the alignment continue if it does....
d. see if the printer is steady and perfect
******* If the printer does not turn on at all then try connecting to the different wall socket / connection....otherwise this printer needs servicing.
Apr 12, 2008 | Office Equipment & Supplies
Printer blinking
The E usually represents paper jam
unplug from wall socket and then replug and try printing
Jan 21, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PhotoSmart InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
