Question about Samsung Prostar 816 Phone
Display Name Dissappeared!!
The display name keeps getting removed, I'm not sure if someone is pressing a button that is doing it but everytime I go back in to reprogram it, my name is still in there it just will not show up. I found the solution once and forgot to write it down... and now I can't find it. Can anyone help me?
    Scholar:
  • 108 Answers
What Samsung System are you using? The older systems program differently and it help narrow down the answer? get back to me and I can help.
Posted on Jul 28, 2008
Hi I have a Nec DT300 at work. I am on a new desk. Do you know how I can change the name which is on the display.
If you have the Admin password then follow this procedure:
For a DT330 (24-Button with 4 line LCD)
Do not lift the handset and press the Speaker button
Enter #*#*
Enter the 4 digit admin password and press the Transfer button
The phone will now display 'Program Mode'
Select Base from the four options using the associated softkey
Enter 15 and press the select softkey 2 times
The Extension Number and Ext Name will be displayed
Find the Extension Number you want to change the Extension Name for using the + and - softkeys
Press the Mic button to go to the Ext Name line
Enter the New Name using the number dial keypad.
If you make an error the Recall button will delete a character to the left and the Hold button will delete all characters to the right of the cursor.
Press the Transfer button to accept the new name.
Press the Answer button 4 times or until 'Program Mode' is displayed.
Press the Speaker button.
The system will save the changes and return the display to normal.
Feb 14, 2015 | NEC Lands Phones
How to Change Display Name
There is no option for it on your extension because your "class of service" is not set for it. Probably the only extension set for name change is 301 if the default configuration was not changed.
Mar 25, 2017 | NEC DSX 22 Corded Phone
All my contacts on phone memory dissappeared (N97) but when someone calls his details appears normally on the screen as if contact was there normally . Connected my phone to PC suite and nothing on t
if you have an Android phone... the contacts are still there they are just not displayed. they may be hidden.
press:
Phone
Contacts
Menu
Settings or Display Settings or Contacts to Display.
(it may be different depending on your phone)
All emails that you have synced with the phone should be displayed. make sure you click each one and check all the boxes including "All Other Contacts"
Hit Save or Done if your phone asks you to.
Oct 30, 2012 | Cell Phones
Putting numbers in the memory and editing
To store numbers in memory do the following
(Make sure the phone is in standby and not in TALK mode)
2.) Press the memory button on the handset or base.
3.) Press the desired memory location button (0 through 9 number keys) or
use the CID-VOL (- or + ) buttons on the handset or CID/rev or CID/skip)
buttons on the base to scroll to desired memory location. If the memory
location is occupied, the stored name and number displays. If the
memory location is unoccupied, EMPTY shows in the display.
4.) Press the memory button again. The display shows ENTER NAME.
5.) Use the base or cordless handset touch-tone pad to enter a name (up to
15 characters).
6.) Press the memory button again to save your selection. The display
shows ENTER TEL NUMBR.
7. Enter the area code followed by the
telephone number (up to 24 digits, including pauses) and press the
memory button again to save your selection. The unit beeps to confirm.
8. To enter another name and number in a different memory location,
return to step 1 and repeat the process.
Manual available HERE
Jun 17, 2011 | Uniden Cordless Phone
Change display names
A problem with answering this question is first that the main SYSTEM keeps this info not the handset, so for the 3x8, 6x16, and 8x24 systems you can do the following (PROVIDED, the installer did not change the passwords to access).
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Press: NEXT Display will read: "B. General Admin"
(NEXT is always the button on the right of your lines/extension list, 2nd button down from top.)
4. Press: SHOW Display will read: "1. Sys speed dial" (SHOW is one key up from NEXT)
5. Press: NEXT Display will read: "2. Names"
6. Press the SHOW Display will read: "Set names"
7. Press: SHOW Display will read: "Show set:__"
8. Enter the extension number of which you wish to change the name Display will read: "<##:name>"
9. Press the CHANGE softkey
10. Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
11. Press: NEXT (if you fail to do this step, the name will not be saved!!!)
12. Press the RLS key
I may be mistaken however I think you have to be on a model M7310, T7316, or M7324 phone (there should be at least one usually at the main desk) in order to program I don't think you can directly do it from the T7208.
Hope this helps.
May 04, 2010 | Nortel Business Series Terminal T7208 -...
My phone dect 6.0 uniden rings when someone calls but will not dial out
Hello :
Maybe you need to program the phone .
Here I'll tell you how :
  1. Press the Down main navigation button and press Menu/OK. The main navigation button is in the center of the keypad and is cylindrical in shape.
  2. Press either the Up or Down main navigation button until "New Entry" appears on the display.
  3. Press the Menu/OK button and "Enter Name" will appear on the display.
  4. Enter the name using the keypad. Enter the names the same way you would enter text in a text message on a mobile phone. For example, to enter the character "H," press the 4 digit twice. Use the labeling on the buttons to guide you.
  5. Press the Menu/OK button after entering the name and "Enter Number" will appear on the display. Enter the phone number using the keypad.
  6. Press the Up or Down navigation button to select "Save" or "Go Back" and then press Menu/OK. The entry is now programmed. Press the goodbye button; it's the button with the phone icon on a cradle.
  7. Press the Down navigation button and the first alphabetical number is displayed. If you keep holding the button, the phone will scroll through your phone book alphabetically.
  8. Press the button with the phone icon on it (not the goodbye button) to dial the number associated with the phone book entry.
I hope that will help .
rate if useful please !
Feb 22, 2010 | Uniden DECT 6.0 Cordless Telephone...
Unable to program buttons on the phone
r u using CTX/CIT system??
this only apply for CTX/CIX
to set extn ket at flexible button
press  #9876
press  HOLD
press the flexible button u wanted to assign
press 610 follow by extn number
press again the plexible button to confirm
repeat step for other flexible button
to set name must go to administrate phone
press MODE at the display
press ADMIN
key in password
default password are ' 0000 '
press HOLD, display will show phone name
press HOLD, again will show DN ID
DN stand for extn
key in extn number then key in name
HOLD again to confirm setting
repeat step for other name
May 26, 2009 | Toshiba DKT-2020-SD telephone
Change my display name
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
Feb 06, 2008 | Panasonic KX-T7630 Corded Phone
Display name
You need to press & hold the "-" minus key to erase the text. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 26, 2007 | iRiver T20 MP3 Player
Speed dials
I'm not sure if this will help because I haven't seen a 2060 control panel but most Canon fax machines use the same process. Press either "menu" or "data registration" button. (Again -I'm not sure of 2060 control panel.) Display should read "user settings" Press the "down arrow" (looks like an upside down triangle) until the display reads "tel settings" Press "set" Display reads Speed Dials Press "set" Display should give the # of the speed dial (ie. Speed Dial 01) Press "set" Display reads "tel number" Press "set" input # you want to send faxes to Press "set" Display reads "Name" Press "set" use letters on keypad to input receivers name (ie. For letter "C" press #2 three times, you may have to use the arrow keys to move the cursor for names such as BC Corp) Once name is input - you guessed it- Press "set" you will now be presented with various other send options which most people/businesses never use. You can hit stop to return to normal mode. After inputting speed dial #'s & names,you can print a list of what you have input by getting back to the "Tel registration" screen & pressing the report button. I can be reached @ bspier@carlsonsupplies.com if you need more assistance. Good Luck!!
Jun 09, 2007 | Canon LaserClass 2060 Fax
Lands Phones Logo
50 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
