Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD420 1200 Spin
My washing machine doesnot complete the wash cycle. The machine turns for few seconds after filling up and then stops. The wash function light then keeps blinking...I just seem to have noticed that this happens when i dont use the machine for a while. Also when it comes back around to its working, some cycles work and some dont. We had the engineer over to check and he di just open the machine up and could not find anything wrong...and surprisingly machine worked just fine...So not sure what to do now??
  • 225 Answers
Hi I have an Indesit WE16 with some of those symptoms and cannot figure it out - so please don't rate this as useless yet! I am beginning to suspect a bad connection to the motor and I have noticed that the drum only turns anticlockwise in my case - if the program calls for clockwise rotation the machine just hums for a few seconds and then stops.
Does this apply to your machine?
Please add a comment and maybe together we can sort both of them out. D
Posted on Jul 22, 2008
Hotpoint washing machine faults
Nicky, try a dry run without a load. Also check if moving to different levels gives you any reading. If not, you have narrowed down where the problem is.
Mar 01, 2014 | Washing Machines
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Hi I have a Maytag model fav6800aww stopped in mid wash cycle,now if you try any cycle it makes a whirling noise for a few seconds then goes to the light flashing pause mode.Thanks.
No erro codes to the console correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual
Sep 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Hotpoint wma22 fills with water but won't wash or spin
Suspect motor brushes need replacing.
Simple task accessed by removing the top of the washer and releasing the clips holding the brushes into the motor - clip on back of brush - to remove the brush assembly.
Replace complete brush assembly.
Feb 16, 2009 | Hotpoint First Edition WMA22 Front Load...
Not draining and flooding my kitchen!
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
please dont forget to rate the helpfulness of this reply thanks kj
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Drum wont turn
check for worn carbon brushs in the motor.good luck!
Dec 01, 2007 | Hotpoint First Edition WMA20 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
138 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
