Question about Neff B1421 Electric Single Oven
The inner glass of my sons built in oven door has fallen out can you please advise how we can fix it thank you it is neff b1420
  • 1 more comment
  • doyle1876 Jul 29, 2008
    B1420 Neff - Inner glass of oven door has also fallen away. The problem is getting a sealant that is heat resistant to those temperuatres. Should I just buy another part new??
  • kiltyman Aug 23, 2008
    my neff 1051-1E CIRCOTHERM OVEN INNER GLASS ON THE DOOR HAS COME OFF CAN OVEN STILL BE USED AND CAN IT BE FIXED.
  • faithdhobbs Jan 23, 2009
    I have the same problem with my Neff oven, Did Siper eventuallyy solve the problem easily or did it need a new door?
No you can buy heat resistant sealant for the sole purpose of fixing glass oven doors,shop around in your area where you live
Posted on Sep 01, 2008
  • 3 Answers
The inner glass panels are bonded to the frame with a heat proof adhesive.
The chances are you will have to get a complete new door assembly.
Posted on Aug 12, 2008
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
Microwave door glass replacement
yes u can refit it normally.but do it carefully.need more help regarding this let me know .
Jun 16, 2008 | Ovens
KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Hi, The inner glass on the door of my Belling 295 SS built in single oven has completely shattered after just preheating it (quite hot although!). I bought it in 2007 so it would be out of warranty. Can...
Hi.
You should not need to replace the complete door, just the door glass.
If you have not already done so, then I would suggest you contact the maker direct, they should be able to help you.
Try the web site.
WWW.BELLING.CO.UK.
Jan 11, 2011 | Ovens
The inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
I have a neff oven, cannot remove glass cover to change bulb. Was advised to buy strap wrench, no good. Advised to heat oven, no good. Cover moves about quarter inch, when heated , nothing. can you please...
Having tried several ways to get the glass cover off, there is one other thing you can try.
Spray some WD40 around the glass cover,and keep trying to tighten and then unscrewng it, and tighten again.
If this does not work, then the last resort is to break the glass cover, which is what I have had to do in the past,. but make sure you can get a replacement cover first.
Please rate my solution.
Thanks.
Nov 24, 2009 | Neff U1721 Double circotherm Electric Oven
After some serious cleaning the inside glass has fallen out. NEFF
It will not be tape as this could catch fire, it is a very high melting point sealant that is used to secure the glass in place.
You can find it for sale on the internet, look under sealants
Thanks.
Nov 20, 2009 | Neff U1721 Double circotherm Electric Oven
Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Mar 12, 2009 | Ovens
Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Nov 23, 2008 | Neff U1661 Double circotherm super...
Glass in oven door is cracked, inner glass completely fallen out
this is a fairly common problem with glass doors on any make of oven
Oct 21, 2008 | Whirlpool RBS305PD Electric Single Oven
Neff B1421 Electric Single Oven Logo
801 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
