Question about Smeg DO81CSS Electric Double Oven
Smeg oven should i be able to take a smeg oven door apart to clean between the glass?
  • Anonymous Apr 13, 2009
    I don't know how to clean between the glass?
  • 49 Answers
Yes
Posted on Aug 19, 2008
Where can I purchase a new door for my smeg oven. SSA91MFP1 sn 80929 1812. The glass shuttered.
Hello Corlia;
My name is Peter. I am a retired field service appliance technician in the USA.
I do not know what country you are in, so go into your computer search engine and search, "Smeg Oven Parts SSA91MFP1".
To purchase an entire oven door will be expensive. Just purchase to glass and install it yourself.
Mar 11, 2016 | Smeg Ovens
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Can I use an abrasive cleaner on the inside glass of my oven door?
I wouldn't do that. I think it would scratch it. I have had good luck using that Mr. Clean pad on my glass stove top without scratching it.
Nov 19, 2009 | Smeg Ovens
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 | Ovens
We have a SMEG self cleaning oven however the glass door is filthy and we are seeking the best approach to clean it without damaging
Purchase 3M stainless cleaner for the stainless parts, do not use spray and wipe or similar as it removes the marking or etching indicators (temp. etc)
You can use oven cleaner on the glass, but try not to let it go on the stainless parts yet again.
Hope this helps?
Jun 21, 2009 | Smeg DO81CSS Electric Double Oven
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
Smeg 90cm oven - removing inner glass plate of door
First you have to unmount the door from your oven (descriped in the manual how to do).
Then next, remove the screws that you have mentioned already of the inside of the door (the inner glass plate is mounted by adhesive on the outer part of the door). After yo have removed the screws, the inner door can be parted from the outer door. Wupti - now you are able to clean the inner side of the glass platen of the oven door.
Per Oding, Denmark
Jan 06, 2009 | Ovens
Cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
Dec 26, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Smeg DO81CSS Electric Double Oven Logo
489 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
