Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher problem Hi My dishwasher will fill with water but the spray cycle doe's not com on. Any ideas ?? Ray
  • mo_young Aug 31, 2008
    Same problem. Dishwasher fills with water, but the spary and wash cycle does not begin. Please help???
  • Anonymous Sep 02, 2008
    Same problem will fill with water sit through a quite cycle and the drain.
  • 725 Answers
1) wash motor seized (remove object)
2) loose motor connection (plug in)
3) start capacitor unpluged or failure (replace capacitor or plug in)
4) motor winding open (replace motor)
5) faulty wash pump circuit (replace control )
let me know and I can help you narrow it down..
Posted on Sep 14, 2008
My dishwasher will fill with water but the spray cycle doe's not com on. but it does drain just fine
If the machine just 'stands' while it should be spraying there could be a problem with the pump or the timer not sending a signal to the pump to run. It the timer is bypassing the spray cycle the fault would be the timer.
Jan 23, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher does not clean properly
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Nov 27, 2010 | Whirlpool Dishwashers
Our dishwasher was cleaning just great...then the next washing...no clean dishes. We thought we forgot to run it, so reran, and the same thing...dirty dishes. Any ideas?
Hi
Daniel
Oct 03, 2010 | Amana Dishwashers
Hi, My whirlpool dish washer does not clean the dishes. Robin
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Daniel
Aug 07, 2010 | Whirlpool Dishwashers
Dishwasher doesn't fill with water!
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 28, 2010 | KitchenAid KUDI24SE Built-in Dishwasher
Hi our dishwasher goes through its cycle but does not dissolve the powder blocks and does not clean the dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | AEG 18 in. Favorit 54750Vi Slim-Line...
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dishwasher - Soap Stuck in Cup If you have dishwasher detergent stuck in the soap cup after a full cycle, please check for the following conditions:
  • The water temperature should be at 120 degrees (140 degrees if your dishwasher has water heating capability). Check your water temperature Check your water temperature.
  • Make sure the soap cup is not blocked by anything.
  • Allow the dishwasher to fill and make sure it is getting a proper amount of water. The dishwasher should fill for about 90 seconds. On permatuf models, the water should measure 3/8" above the island near the center of the tub. On all other models, the water should measure about 1/2" below the heating element.
  • Check the lower spray arm for any blockage in spray holes or items that would restrict its turning.
  • Make sure the soap cup has opened at the end of the cycle.
  • Check the sump area inside the dishwasher for any restrictions.
Apr 09, 2009 | Maytag 24 in. MDBH950AWS Built-in...
GE Dishwasher fills with water but does not "spray water" on dish
Here are a few things that might help you out, first is you could have a bad heating element in your dish washer, when it fills with water it has to reach a certain temperature before continuing to the next cycle, next thing is you could have a bad thermostat, or your timer is defective.
Mar 16, 2009 | Kenmore 16522 Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
395 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
