Feeding from top
I am unable to feed my paper thru the top to make a copy- when I press copy it assumes that the paper is on the glass. Brother model 8440
    Sergeant:
  • 329 Answers
There is a switch in the document feeder that tells the machine there is a paper there. This switch is not being hit by the paper or the switch is not moving freely. With a flash lite you should be able to see this switch move.
Posted on Jul 22, 2008
There is a vertical black line appearing when I scan or copy
To the left of the A4 scanner glass, there is a narrow glass strip. This is when the top document feeder scans from. Check for any contamination (even a small speck) on this glass at about the position of the vertical line.
Mar 29, 2015 | Brother MFC-9440CN Multifunction Printer
When I feed copies thru top feeder a black lines appears down one side of paper
This type of problem is usually caused by something like white out or lint stuck to the scanner glass. Open the top of the scanner and clean all of the glass surfaces with window cleaner sprayed on a paper towel ( do not spray on the glass) , allow it to dry and then try to scan. Here is a link to some pictures that show what to clean.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
I hope this helps,
BuddyMc
Jul 24, 2012 | Brother DCP-7040 Laser Printer
Line thru the documents when using top feeder
you didn't state model #, but raise your feeder up and look for the "skinny" piece of glass on left side of your large glass and make sure you clean it well.
hth,
razors
Nov 28, 2011 | Brother Office Equipment & Supplies
The feeder in my office copier is not feeding the paper thru it. It only copies if you manually put it on the glass.
Hi, you need to open the adf cover, check for any leftovers of paper or clips, or... also clean the pick up and feed roller with alcohol by piece of fabric.
Also have on mind that the feeder is only for plain paper usage.
Sep 08, 2010 | Canon imageRUNNER 1023iF Black and White...
Our HP laserjet M1522n has a vertical line going through the paper when using the top feed. the line doesn't appear on copies made thru the computer or on the flatbed, only thru the self feed. any one??...
If you open your "self feed" cover, you should be able to see the scan glass that originals pass over to copy. Clean that glass thoroughly. There is some dirt or whiteout (liquid paper) on it which causes the shadow or line on copies. Let me know.
Oct 15, 2009 | HP LaserJet M1522n MultiFunction Printer
PAPERS WONT FEED THRU TOP FEEDER
im having the same problem was working fine then quit feeding
Mar 31, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
We have a Brother FAX-1840c. It will jam feeding paper into the scanner. I maintenance mode it returns an A1 error code. Feed rollers look serviceable and the pressure pad is clean. Stops half way thru...
Hi
There must be some torn paper or something stuck in the Paper feed. You will need to ope the upper face portion by pulling it, and then look for papers/ dirt / pins there, you can either clean it by blowing air or use a blower, or if you can see the particle. Try feeding the paper, it should be ok.
Jan 27, 2009 | Brother IntelliFAX 1840C Plain Paper...
I have a brother copier model dcp 7025 and am experiencing a vertical line on copies where the original is fed through the top feeder tray but the copies are fine when the original is placed directly onto...
Depends which way is vertical but I think the feed rollers on the upper tray are slipping perhaps dirty. (The paper momentarily stops feeding past the scan sensor)
Jul 14, 2008 | Brother Office Equipment & Supplies
Lines on making copies
clean the glass of the scanning area, a small dot of debris on the glass produces a vertical line from top to bottom in the feeding direction of the laser printer.
May 07, 2008 | HP LaserJet 3055 All-In-One Printer
44 people viewed this question
k24674
jasbo
jasbo
