Question about Maytag Washing Machines
I have a maytag neptune washer and the water coninually runs and wont shut off. Would this be a computer problem or is could it be a clogged filter? Any suggestions would help. Thanks.
    Genius:
  • 1,028 Answers
Probably fill valve not closing off fully due to trash in valve ..have the screens been removed?
Posted on Jul 23, 2008
Washer wont pump out the water and wont shut off if not unplugged
Heres a great website: Go there and investigate the videos
http://www.repairclinic.com/Shop-For-Parts?SearchText=Maytag%2520Neptune%2520FAV6800AW
Feb 18, 2015 | Maytag Neptune FAV6800AW Top Load Washer
I haveno idea how there continues to be water run inside the washer after the cycle runs through. I have even shut the water off and there seems to be water still running inside,
Turn off your hot and cold water valves. Your water valve inside the washer has gone bad. What happens is the valves open and close there is suppose to be a filter screen on both hot and cold inlets where you connect the water hoses to. If not the debris from the water line gets in there and clogs it up leaving the valve open which is causing your problem. Also seen it where people on well water have this problem a lot because the water might be hard with sediment . You can have a qualified technician come fix it won't be too expensive hope this helps and thank you for using FixYa!
Jan 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
Neptune Maytag washer wont fill with water
Check to see if your valves are on. If they are, they might be clogged or the pump is obstructed/dead.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Matag neptun front load washer wont drain
You have a clog in your pump; have to dismantle to de-clog. Look carefully.
Tip:
Empty out all pockets in clothing before loading the machine!
Mar 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Mar 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine it shuts down water filling cycle
First thing to check is the filter,
DISCONNECT power
open the bottom pane (3 screws on bottom front lip)
in the cent is a large removable filter ,
set a pan or rags under it ,there will be water.
clean out any debris an be sure the pump impellers move freely.
let me know if that fixes it.
Jan 29, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah3000aww
re original issue, see if R11 is burned. if so, need to change R11 resistor and associated triac, and probably wax motor so it won't do it again. temporary fix just cut out R11, door won't lock. if your model won't spin that way, depress actuator for microswitch from door wax motor. instructions on web.
Jan 19, 2008 | Maytag Neptune Washer
Washing Machines Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
