Question about Hotpoint Washing Machines
We have no instructions for our new Hotpoint Washing Machine Ultima 7kg WT960G - how do we fit it?
    Problem Solver:
How to change cold water valve on washing machine hotpoint WT960G
Posted on Jan 09, 2010
Ring Hotpoint who will send One e-mail or post
Posted on Oct 06, 2008
Instruction manual for hotpoint aquarius WDL540 7kg Washer/dryer
My washing machine's indicator flashing after 5 minutes,what should i do?
May 13, 2012 | Washing Machines
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
Hotpoint Ultima Washing machine 7kg drum, not recieving any power atall had main mother board changed and hasnt resolved problem what else can it be and can i fix it my self?
if you have a multimeter,you can check voltage and cable may be worth fitting new door interlock if machine not starting mains led on........Could be mains filter capacitor
Apr 07, 2010 | Hotpoint Ultima WF860 Front Load Washer
What does a fault F01 signify on a Hotpoint Ultima 7kg washing machine?
Error code F01 indicates a short circuit motor triac.
Thoroughly check all connections on the motor, the motor plug, and the electronic module board..
Look for a broken wire, or a bad connection.
Please rate my solution.
Thankyou.
Jan 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
Changing door seal on hotpoint ultima washing machine
hello if you take the top off the washer and look down inside you should see a metal ring with long screw and nut unscrew this so it's loose you should be able to pull the seal off .then on the front of the washer where the next part of the seal is theres another rmetal thin bit of wire . unscrew the platic clip and the wire should come off. then just pull the seal out of the washer and when you put the new seal on fit it the same way you took it off good luck ps get back to me if you get stuck
shaun
Sep 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
Changing the door gasket on Hotpoint Ultima WD860
Managed to work it out myself how to take the old door gasket off and attach the new one. Thanks. Machine working okay with no leaks or mould anywhere now.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
212 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
