FixYa.com
Tags:
D-Link DFE-530TX Network Adapter
Running at 10 mbps
posted by jteich on Jul 22, 2008
D-Link DFE-530TX indicates that it is only running at 10 mbps. I an using a Cat 5 cable and cant get it to run at 100 mbps. Dell 8200, PCI slot, Windows XP.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2008
Not Rated (0)
xSWAYx
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
There's possibility that the network (router/modem/switch) you're trying to connect has limit to up to 10 Mbps only. Or it can be that the current LinkSpeed of the Ethernet adapter might be forced to 10 Mbps. Do the following to check this setting:
  1. Go to Control Panel> Network Connections.
  2. On Network Connections, look for Local Area Connection (for the D-Link adapter). Right click it then go to Properties.
  3. On Properties window, click Configure button.
  4. On the next window, go to Advanced tab.
  5. Look for Media Type, Connection Type, or LinkSpeed and Duplex Mode.
If the value is set to Auto Negotiation/ Auto/ AutoSense, try to force it to 100 Mbps.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Network Adapters problems?
Network Adapters
microsoft isatap adapter #15
i cant find the solution why my... Answer This...
Network Adapters
siemens dc drive dc500s
control card not com with... Answer This...
Network Adapters
lan drivers problem
hi  munish here actually... Answer This...
Network Adapters
Network adapter disconnected
Both isatap adapter on my... Answer This...
Network Adapters
hi there
i have compass 597 and for a... Answer This...
Repair Service
Find Network Adapter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
