Question about Lands Phones
Auto Attendant I found a manual that explains how to change the auto attendant; hwoever the manual says to hit intertcom, 777, 0#. When I do this and hit 0 I get transferred to the receptionist. Please help
  • 2 more comments
  • bolson Jul 22, 2008
    It is a Lucent AT&T partner plus phone system. It is pretty old.
    When I dial 777 the voicemail picks up and asks for an extension and password. The manual says to press 0#; however when I press 0 I am transferred to the receptionist.
    It says release 5
    It worked!
    Thank you so much for your help!
  • Anonymous May 11, 2010
    Which system do you have?
    When you dial intercom 777, does the voicemail answer?
You are trying to access the admin mailbox for a newer voicemail than your system supports.
After dialing intercom777, try 99# and 1234#.
That will get you into the voicemail, and it will tell you the release (Partner mail VS rel 4, 5, etc...)
Need to know that for further instructions.
Posted on Jul 22, 2008
  • Anonymous Jul 22, 2008
    1. Dial Intercom 777
    2. Dial 99#
    3. Dial 1234#
    4. Dial 9
    5. Dial 3 For the Auto Attendant
    6. Dial 1 for the day menu and 2 for the night menu.
    7. Dial 6 to modify the menu
    8. Dial * # (you are not making changes to the selector codes)
    9. Dial 1 to modify the menu prompt
    10. Lift handset and Dial 1 to record, press 1 when finished
    11. Choose an option: 21 to rerecord, or 23 to play back
    12. Dial * # to save the recording.
Turn off the auto attendant for the Nortel Phone System
To turn off the auto attendant:
Press the program key. The display will indicate:
Press the key under ANSW. The display will indicate:
Press the key under CHANGE. The display will indicate:
That's it. Now press the program key to finish. If you need more detailed instructions, please follow the user manual: Nortel pdf manual
Oct 28, 2013 | Nortel Computers & Internet
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
Change Auto Attendant message to Rollover Calls to Ext. 10 and 15
**use with care ** if it is a "Partner System" here you go. if unsure do not do this. it is simple but one wrong keypress will cause ... mmm problems. so just hang up if unsure. dial intercom 777 , then * to get main greeting, if ok then * again then enter extesion should be prompted. press 0 # then password , default is 12345678 #. if it is good dial 9 (administration) then 3 (auto attendant) then 1 , 1, 6, * , # then 1 to record and follow prompts.
Oct 10, 2009 | Lucent PARTNER18 Corded Phone
Auto attendant
In order to do that, you need to know which Auto Attendant you have. I'd recommend calling a Panasonic technician (you call them engineers).
Here's a manual just in case you what to take a whack at it.
Mar 23, 2009 | Panasonic Lands Phones
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Auto attendant
I was poking around on the web and found your question. I designed the SI-460 a few years back. Casio, sadly, shut down their phone division.
I can e-mail you the owners manual (PDF) if you need it.Anyway, in case you haven't figured it out:
Press the PROGRAM key.
the display will indicate:
Press the program key to end the process.
Good Luck.
Joseph Quevedo
Jan 17, 2008 | Casio SI-460 Corded Phone
Cant get auto attendant to turn off.
What are you trying to do. It isnt that easy to turn the Auto Attendant partially off....
Jan 17, 2008 | Avaya Magic Voice Mail Automated Attendant...
Lands Phones Logo
257 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
