Question about Saeco Magic De Luxe Espresso Machine
Saeco magic comfort coffee machine grinder
The display on the machine says "coffee beans empty ready for use" There are beans, I have cleaned the machine, I push the selection and it hums away with no beans being ground. What is the problem and How do I fix it.? Thanks
  • 1 more comment
  • johnpaull Aug 30, 2008
    My menu reads 'coffee beans empty' but it is full. I have cleaned and descaled the machine but don't know what else to try.
  • awcjc May 11, 2010
    My menu reads 'coffee beans empty' but it is full. I have removed the coffee beam container and cleaned the machine and grinder area but don't know what else to try.
  • Anonymous Mar 31, 2014
    it says " coffee beans empty" and there are coffee beans inside,
Empty beans out. Take the two screws out.
Put bean grade to 1. Run the machine as if making coffee. Use a vacuum and clean the bean grinding machine area. Run the machine again.
Place bean container back and put screws back in. Fill bean container.
This worked for me
Posted on Aug 30, 2008
  • Jim Hiatrides Aug 20, 2012
    This worked for me but I had to put the grind up to the max
  • 515 Answers
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Posted on Jul 22, 2008
I accidentally put water in the grinder will it dry out
no,will not dry .You have to take off the beans canister and get out the grinder knife to clean it.
Jul 11, 2014 | Saeco Magic Comfort Plus Espresso Machine
Tip
Fix Saeco Magic De Luxe Not Grinding problem
If you leave the machine for a while, the residual ground beans in the grinder stick and clog the grinder.
- thus "timing out" with the "No beans" light.
After taking apart the grinder and cleaning it out, it still didn't grind. -
Then we ran some ground beans through it a couple of times, and then put fresh whole beans on top of the preground, and it took.
Worked great after that.
on May 06, 2009 | Saeco Magic De Luxe Espresso Machine
Coffe Machine Saeco Magic Comfort
the coffee beans grinder is too fine .Turn to next number,
Oct 29, 2013 | Saeco Magic Comfort Plus Espresso Machine
Grinder not working
Hi, I had this same problem. Call Saeco and they will e-mail you detailed instructions on how to clean the grinder (2 page pdf file). The directions were great and it fixed our machine. Ours kept telling us to add beans, and the grinder continued to spin. It wouldn't load the beans into the grinder. once we cleaned it (completely) it worked fine.
Dec 27, 2010 | Saeco Magic Comfort Plus Espresso Machine
My machine drinds coffee in large pieces.It doesnt grind when I set the regulator on 6 or 7 and appears message "Coffee beans is empty"
HI
One possible problem is your grinder has become separated, so your beans are not feeding equally. The beans are going to one side of the burrs and are ground into big chunks. If you remove the beans in the bean hopper and look down on the grinder. If the cork screw is off to one side that is your problem. Of you can move the cork screw from side to side you need to replace your grinder in either case.
Oct 12, 2009 | Saeco Magic Comfort Plus Espresso Machine
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
Either the coffee chute from the grinder is blocked, or the grind is too fine. Remove brew unit and check grinder chute.
Sep 28, 2009 | Saeco Royal Digital Plus Coffee...
Saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
Aug 17, 2008 | Saeco Magic De Luxe Espresso Machine
Magic Comfort Plus making thin coffee
i had this problem and it ended up being the grinder.  i called to get support from the parent company and they sent me instructions that explained how to adjust the grinder.  the instructions included pictures as an aid also.  ultimately, it was a simple fix that took, perhaps, 30 mins or so.  give that a try also.
Aug 11, 2008 | Saeco Magic Comfort Plus Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
The Coffee bean holder
You may have accidentally dropped water into the grinders. Email me your email address and I'll send you grinder cleaning instructions.
If the grinder cleaning does not work.. You may have to have to machine serviced.
Please include the model of machine and that you would like the grinder cleaning instructions.
Email: support@cerinicoffee.com
Oct 06, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
1,670 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
