Question about AEG Lavamat 16810 Front Load Washer/Dryer
AEG 16810 UPGRADE WASHER DRYER E10 ERROR
AEG worked great until a repair man came to fit a new door haldle - then the machine started making steam. E10 error light. Changed one valve and the thing still overheats and makes steam after 20 minutes. The repair man is getting hacked off with coming to look at it. The machine washes perfectly. Please help.
  • 1 more comment
  • Alex Forsyth Oct 28, 2008
    I have the same problem on a Lavamat 16830. The engineer has now been out twice, and we still have the same issue.
    The washing cyce is fine, and the first drying cycle is normally OK, but the 2nd fails after about 10 minutes with the E10 error.
  • Anonymous Nov 28, 2008
    We have the same problem - no drying, and E10 APPEARS ON THE SCREEN. Which VALVE requires replacement?
    Thanks,
    Linda
  • Anonymous Mar 29, 2014
    I can't start any programme with my wash dryer..every time I get error code E10. Any idea ?
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Posted on Aug 03, 2008
Hi - what valve is it that needs replacing? I have same problem, very annoying!
Chris
Posted on Feb 13, 2010
WHAT IS ERROR E40 MEAN?
Its a defective door lock. It might have to be replaced by a techie! Hope its under warranty
Mar 08, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
E1O DISPLAYED
The other E10 fault is a clogged drain pump. Instructions to clean and free this are in the user manual obtained here. http://www.aeg.co.uk/Support/Manuals/
Peter Kay
AEG Lavamat 16810
E10 is related to water flow and if it isn't due to the 3-way valve being defective there's another common point to check.
The back and side cover needs to be removed to get at the condenser that, over time, can fill with fluff and stop the hot air from circulating. It and its connecting pipes can be unclipped and cleaned out.
Oct 17, 2013 | AEG Lavamat 16810 Front Load Washer/Dryer
Door wont lock befor i start washing mashine after i fixd handel wa cud be rong
door locks can be tricky did you replace the complete door assembly with new ?
and did you brake the door handle that is why you fitted a new one ?
have you also replaced the inner door lock?
let me know
Dec 10, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
I have an AEG Electrolux 16830 - I get an error code E10 - pressing the start switch recommences the program and it completes as normal. How do I reset the machine so this does not happen. An engineer...
E10 indicates that the water inlet hose is squashed or kinked.
First check the filter for coins or other junks.
Make sure the drain hose isn't blocked, restricted or kinked.
Hope this helps.. Good luck! ;)
Thanks for using
FixYa - a 4-thumbs up rating is greatly appreciated for answering your free question
Jun 06, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
What does E10 mean? is this an error
E10 means your machine has not filled to the correct water level (10 mins allowed) low water flow or blocked filter in the water valve . or faulty valve.check tap is turned on.
Jun 17, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
My aeg lavamat 16810 washer dryer won't dry. The error message is E10, meaning the water isn't going in. Water is running until the dryer kicks in, then the valve closes and it stops. The heater etc are...
I had the same problem and fixed it by replacing the triple valve. One of the inlets passes water to the condenser and this had failed. You can tell this by opening up the top and when the drier starts you here the drain working and then should hear a gentle hiss as the water is let through. If you don't hear anything then after 10 mins you get the E10 error. It cost me £27 which is cheaper than getting a new machine or a call out charge. If you feel competent then all you need is a philips screwdriver, pliers to get the clips off and a flat head driver to remove the rubber hoses.
Oct 28, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
E10 PROPLEM AEG
Your Machine manual is HERE
E10 is an inlet fault.
Check the water valve is turned on. If you are only getting a dribble of water in, then clean the inline filter at the hose inlet.
If no sound of inlet water - replace inlet valve (available as a spare from online stores)
Sep 30, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
I have an AEG Lavamat 16820 washer dryer and the door wont open any ideas
The lock is rubbish on this machine but as a temporary measure you can feed a string down behind the door lock from the top and out the bottom. Then yank it to the left to open the lock. It will take a few tries but you get the hang of it!
We got sick of this so ordered a new lock off the net. I basically had to break the old mechanism to fit the new one because the door layers were so strongly glued together. Now fitted, the lock works perfectly but the machine thinks the door's open the whole time! Next step is either new door or new machine. Great.
May 04, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavomat 54810
Might be Abel problem good luck
Dec 17, 2017 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
3,417 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
