Question about JVC HR-XVC17S
Remote quit working.Changed batteries and no help. Can't change speed without remote. Why wold it just quit working?
Did you drop the remote? IF yes the PC board might be cracked or the IR diode at the front of the remote might have just died. Try and look for broken pattern near the IR diode or apparent cracks in the PCB. If you find a break in the foil pattern, simply scratch off the green varnish on the board and solder a wire jumper over the cracked pattern. Once tested operational the apply some epoxy glue to the board to solidify it. Best of luck
Posted on Oct 20, 2008
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
My DirecTV remote completely quit working. I
Is the DVR the problem or the DirectTV remote?
If it's the DVR, DirectTV will send you a replacement and you will have to return the faulty unit. If it's the remote, you can buy a replacement online at directtv.com.
Jul 31, 2009 | Directv RC-64 Remote Control
Vrdvd4005, remote quit, changed batteries,
I would almost stake my life that the inferred diode is the problem, this has happend to mine in the past I replaced the diode and it has worked for years now.
Jul 07, 2009 | Sansui LCDWDVD320 32 in. TV/DVD Combo
Changed batteries and now remote won't work
sometimes if the batter is of expired stock then also it does not work.also try to clean the contacts in the sockets where u insert the battery.if still does not works then its quite possible that the internal circuit of the remote has gone fasulty.so the remote now needs replacement.
Dec 11, 2008 | Sharp Televison & Video
Remote not working at all
Check the fan and the remote to see the code switches are same. Sometimes depending on the age and humidity you may have to slide the switches back and forth to clean the contacts. Did it ever work? Are the batteries in the proper polarities? The fan and remote have to have the same numbers picked to operate properly.
Nov 16, 2008 | Hampton Bay 48670 Flemish Pewter Finish...
Universal remote
I CHANGED THE BATTERIES IN THE REMOTE BUT THE REMOTE QUIT WORKING.IT LIGHTS UP BUT WONT FUNCTION.Need the code,My TV is Sharp
Aug 24, 2008 | One For All URC4220 Remote Control
JVC HR-XVC17S Logo
76 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
