Hi Guru, following is our conversation from yesterday. Can you help me find a solution for my door locked blinking problem. Unplugging the range did not work.
I used the oven self cleaning option and since then I have a blinking ' door lockez sign' and my oven does not work. Do you have a solution for me Guru ?
Comment by lindajohnsto, posted on Jul 22, 2008
I tried what you suggested and it did not work. Can I try anything else ?
Thank you very much
Clarification Request
by jsrock516, posted on Jul 21, 2008So many problems occur when people use the self cleaning features on their ovens. If you ask me, this feature is more trouble than its worth. I don't have a clear resolution for you, but I have a few suggestions. First, try unplugging the range for at least 30 minutes to see if the Electronic Oven Control (EOC) will reset itself. If that doesn't correct it, you may have a door lock that is jammed, or an EOC that has failed. Try the preliminary step, first and let me know the results.
1 Other User Has The Same Problem
Comment by paulface, posted on Aug 06, 2008
door lock has been on our ge xl gas range and itr won't work, we were told that the latch mechanism needs to be replaced to the tune of $350.00. oven is only 5 years old. want to know if there is anyway of disconnecting door latch to make sure all other parts are functioning normal. thank for you help paula
Post a New problem for GE Profile Spectra JGBP90 Gas Kitchen
Email this problem
Can you Help with these Kitchen Ranges problems?
Jammed storage drawer
Range Mabe 30" 1700TLE
I cannot get door to latch for...
oven broke-ge spectra XL44 made...
