Question about Sylvania LC320SS8 32 in. LCD Television
Is this TV wall mountable?
I have this small LCD TV. I cannot tell whether it can be wall mounted or not?
Can it?
Jan Is this TV wall-mountable? If so, how can you get the pedestal base off? Thanks!
  • Dan_C069 Dec 06, 2008
    I have a Sanus Systems VM400. It's an expensive bracket with an arm that swings out, and a pivoting headpiece. But how do I mount it to this TV? I don't see any holes to screw into on the back panel?? There's 4 holes right in the dead center of the TV, but there's already screws in them! I really don't feel comfortable taking them out!
    Problem Solver:
  • 11 Answers
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Posted on Aug 04, 2008
SOURCE:
I have SOYO MT-+SYTPT3227AB TV and cannot locate mounting holes to wall mount the TV.
This TV is not Wall Mountable as the Control Box protrudes and is therefore not suitable for a VESA Wall Mount.
Jun 10, 2011 | Soyo Televison & Video
My tv is a 42 inch toshiba model#42HL67 im trying to remove the base from the tv so that i can mount my tv
Hi, I have looked into whether or not this t.v. is wall mountable. The only way to tell if this is possible will be to look on the back of t.v. and if wall mounting is possible then there will be 4 screw holes approximately 15 inches apart forming a square. If these " mounting holes are not present then there is no way to mount the wall bracket. Second if holes are present there may be a protective plastic cover at the top of the table top stand where it meets the t.v.. It more than likely is just a snap on type situation and a little bit of prying will pop it off revealing the screws. I hope this has been useful, and thanks for asking FixYa, Good luck- Prodzilla.
Apr 20, 2011 | Toshiba 42HL67 42 in. LCD Television
How think is this tv and is it wall mount able
It is wall mountable with a VESA Mount: 400 x 200 mm according to the installation guide (600 x 200 mm in the specs). The depth without stand is not given; other Magnovox TFT LCD televisions are about 5-6" in depth (4.9" for the 42MF439B/F7 )
A compatible wall mount is here: http://amazon.skakawack.com/Silver-Tilting-Wall-Mount-Bracket-for/M/B0019D4K6M.htm?traffic_src=froogle&utm_medium=organic&utm_source=froogle .
I hope this helps.
Nov 23, 2010 | Philips Magnavox 42MF521D/37 Television
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
Can u take the bit off that attatches the stand because i want to hang mine on the wall?
Yes allmost all flat screens are wall mounteable. It will require find the screws or bolts holding the table mount to tv and removing. If your tv has extra threaded holes on back then it is mountable.
Dec 31, 2009 | Samsung LN-R268W 26 in. HD-Ready LCD...
Non wall mountable samsung tv
Take the feet off. See the manual.
May 24, 2008 | Televison & Video
ILO 32" LCD
yes it is mountable. the 4 bolts are metric size is 6mm -1.0 x 40 mm
Use are large tv wall mount unit and buy the bolts seperately. I just hung mine and the
only problem I am having is I cannot remove the table top mount off the bottom of my TV
Can you halp??
Mar 29, 2008 | iLO 3200 32 in. LCD Television
Wall mounting
According to the manufacturer (and numerous websites selling this TV) there is no provision to mount this TV by normal industry standards. It should state clearly on the box or manual what the mounting standard is if it is mountable, and in this case its not. Sorry.
Mar 23, 2008 | Westinghouse LTV-19W3 19 in. LCD...
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
The stand on the bottom
There are a number of small silver phillips head screws atteching the base to the back of the set. Remove these and the base will come off. I would suggest that you replace the screws into the back of the set so they won't be lost. I assume you have purchased the proper mounting bracket. If you shop at Wal Mart, they carry two sizes. The 32" will require the largest size. This info applies to what I purchased, which was the 32" LCD flat panel wall mountable unit. I hope I have been some help.....timitot2
Aug 23, 2007 | iLO 3200 32 in. LCD Television
Sylvania LC320SS8 32 in. LCD Television Logo
629 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
