If your sub woofers are DVC 4OHM: Connecting three together in Parallel/Parallel would make your amplifier run a 0.67OHM load or if connected Series/Parallel then you would have a 2.67OHM load. If your sub woofers are DVC 2OHM: Connecting three together in Parallel/Parallel would make your amplifier run a 0.36OHM load or if connected Seies/Parallel then you would have a 1.67OHM load and Series/Series a 12OHM load. So if your sub woofers are really DVC, it would be impossible that your amp would be playing 4OHM. The numbers just don't add up. There are amplifiers out there that can deal with 0.50OHM loads but expect them to be on the pricey side, but fairly so, because mostly higher end brands tend to manufacture them and are usually pretty good. Remove 1 of the sub woofers. If i knew what the subs where 4 or 2 OHM DVC and what amplifier you are using i would tell you how to connect them for the best possible result. hope this helps dreamsystems
