I set the temperture to 76 degree on my white-rodgers ( type 1f89-11) termastat and it revert back to 82 degree.
  • 80 Answers
THIS MAYBE PROGRAMMABLE, AND IF SO ITS EASIER JUST TO CHANGE THE THERMOSTAT YOU CAN GET A NEW T-STAT FOR $20.00
Posted on Jul 24, 2008
SOURCE:
I have a White Rodgers thermostat series 1F78-151 that is displaying we at the top?
Hi. This is Aaron Moratalla from White Rodgers. For 1F78-151, "WE" means Wednesday. If left side temperature is stuck at 67F and there's no Hot air coming out then try ressting your thermostat by:
1. set system to Heat mode
2. press simultaneously the Up, Down arrows and Time button for 2sec.
3. the screen should blank out momentarily then show 62F in the right side.
4. set a higher temperature in the right side than the left side of LCD to have a call for heat.
If you are still having problems please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
I have a white rodgers thermostat 1F80-361 and my air conditioner blows out cool air for about an hour then it stips and blows out a air like temperture. The current temperature always says 80 and above...
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from White- Rodger's. Base on your description you have a system problem not a thermostat issue. You need to contact your installer to check you cool equipment.
Aug 04, 2012 | Heating & Cooling
White rodgers customer service phone number
we are not white rodgers /emerson --the following links can assist you but if the trooble shooting doesnt fix problem just replace the stat
White Rodgers White Rodgers White Rodgers Thermostats Thermostat AC Wholesalers How to Troubleshoot White Rodgers Thermostat eHow
May 30, 2017 | Heating & Cooling
I have a problem with a White rodgers 1C20-101 thermostat. The lower heat setting for room temp goes up to 80 degrees when the thermostat is set at 70 degrees. Is this normal for this type of unit?
The Operating Manuals for many White-Rodgers thermostats can be found in PDF form HERE, however they are not indexed by model number so you will have to download each file in turn until you find the one you want. All of the file names beginning with "0037-" seem to be W-R products.*Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Oct 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Keeps going to 62 like it's on a program
You need to manually operate the thermostat by using the hold button. You did not specify the model number but try this procedure:
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set toHEAT or COOL, momentarily press HOLD button. HOLD will be displayed. Use UP or DOWN to adjust the temperature.The thermostat will hold the room temperature at theselected setting until you press RUN button to return to program operation.
If you need further clarification please cal hometechline 18002842925. I hope this will help you a lot...
Oct 29, 2009 | White Rodgers White-Rodgers 1F85RF-275...
IF81-261 TO MAINTAIN 76 DEGRES JUAST SET ON AUTO AND 76 IS THIS CORRECT ITS IN A BAR ? DO I HAE TO PUSH HOLD WHEN THE SPACE GETS TO 76 DEGREES ?I DONT WANT TO USE THE CLOCK SETINGS AS THE HOURS ARE...
First of all this thermostat doesn't have a auto change over feature.
To maintain the desired set point of 76F, is press first the system button to the system that you want either heat or cool and the next step that you need to do is to navigate the UP or DOWN arroes for your desired set point and It should follow that temperature permanently until you cjnage it again.
Aug 08, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Temp too high
lamgrimes9,
Welcome to Fizya.,
You said, your Oster wine refrig won't lower its temperature below 76 degrees. I have it for about 5 months, and it worked fine all this time with a setting of 50 degrees. Now it refuses to lower its temp. It reverts back to 76 everytime. Can someone give me any ideas about what is wrong? FYI Mine did not come with an owner's manual.
Sounds like the Thermostat is bad.
http://www.oster.com/CustService.aspx?content=manual
The tel # in your Oster Manual is a recording and will not help you!
But New appliances are under Factory warranty and are fixed or replaced no cost to the customer!you are under
http://www.oster.com/CustService.aspx?content=center
Let me know how it goes.
Huuum
Please leave a rating.
Oct 05, 2008 | Oster 12-Bottle Wine Cellar - Black
Heating & Cooling Logo
316 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
