Question about Samsung Blackjack SGH-I607 Smartphone
Keypad dead i made a call and afterwards, the keypad no longer worked from start. If i find a contact through contacts and hit the green phone button to dial i get an error message; "Cannot complete the call..."
I went by an at&t store and all my phone needed was a re-boot, which is to say i had to remive the back and the battery while it was on, give it several seconds, then replace it. everything is back to working fine now.
Posted on Jul 23, 2008
O2 Xda Stealth: Can't Call and Access Contacts
first, back up all of your data and then reboot it by..
- turn off your phone
- then press these 3 buttons at the same time and hold them for 5 seconds
* power button
* window button
* OK button
Feb 07, 2009 | O2 Xda Stealth Smartphone
Can receive calls and texts but none of my buttons are working, I mean none. I can't answer calls or even turn on/off the phone. Could this be my battery is no good?
This usually means your keyboard is defective.
First try installing the OS on the phone either reinstall the old os or try and upgraded version.
A.) Remove the battery, Plug in( if keyboard still does not work try the following:
1.) Applications
2.) Options
3.) General settings
Note: your phone may have a different os than I pulled the above information from just try to get to general settings and then hit blackberry button for wipe handheld option. Don't forget to backup your contacts etc before doing this.
Depress the blackberry button (button with all the dots on it) then select wipe hand held. Be careful as this will erase possibly everything on the handheld
If none of the above work to get your keypad working it will need physical repair.
Jan 06, 2009 | RIM BlackBerry Pearl 8100
Key pad on blackberry pearl not working
either the phone got wet or its just a bad phone. i would call the company and see to get a replacement model, that is if it is under its warranty of two years.
Dec 16, 2008 | RIM BlackBerry Pearl 8100
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
Failure to add contact
There are usually more than one way to add contacts to a cell phone, what if you type the number in to your keypad, then hit options and then save? same error?
Dec 09, 2008 | Motorola Mobility A1200
My handset 3230automatically restarts and ask web connection
turn off ur mobile.
follow the folwing instructions.
press and hold this 3 buttons till the phones start
1.green button use for accepting calls.
2. * key there on the keypad.
3. number 3 in ur keypad.
now start phone
press and hold untill the phones starts
it takes some time then normal bootup of ur phone
but it will reset ur phone
another trick is
*#7370# and call from ur phone
try this both trick it works
Nov 25, 2008 | Nokia 3230
My mobile is dead
I just had this happen to me yesterday. I fought with my phone for about 3 hours removing the battery and trying to restart it. It would take about 5 minutes for it to finally boot and once it did the touch screen would not work. So I did a hard boot and within 5 minutes my phone was back to normal. I lost all my contacts but I just did a restore with the backup software. To do a hard boot hold down the red and green buttons on the front of the phone and push the reset button on the bottom of the phone with the stylus. The reset button is on the right side of the power/usb plug. As I said my phone was back to normal in just a few minutes.
Jul 16, 2008 | HTC Touch P3450 Smartphone
UNCOMPLETED MDA UPDATE
this is a sw boot up screen. this is what the screen will look like with no sw on the device, so you guessed it....the download was unsuccessful and corrupted the firmware.....if you tried to reinstall the sw again, and it does not work, you might need a new phone....contact t-mobile to do that.....OR, you can try to do a master reset by pressing the sw keys.
to do that, turn off the phone, and press and hold the soft keys (buttons located beneath the touch screen that have the lines on them on top of the green call button and the red end call button).....while holding these down, press the power button for 3 seconds and release the power button.....all this time you are holding those soft keys down....the phone SHOULD turn on and go to a black screen with white writing.....at this time you can relase the two buttons......press the green button and reset. if this does not work.....my friend, you need another one......good luck!
Dec 16, 2007 | T-Mobile MDA
Samsumg C300
ok... your keypad flex might get loose or dirty keypad contacts inside or check your volume if it get stuck... or
if you can open your phone, checks its connection or keypads contacts get dirty...
hope that solves your prob...
Oct 29, 2007 | Samsung SPH-i500 Handheld
Problem is""phone star-up failed. contact the retailer"
The best solution for this problem is to format the phone memory. U may think format will erase all applications but it is false . The essential softwares like mp3 player, camera, etc. are not erased.
The process for format of phone is :
1) turn off the mobile.
2) press and hold ( green dial button + 3 keypad + * ) and turn on the phone holding these 3 buttons(dial button + 3 + *) until formatting screen appears.
3) When formatting screen appears, just leave the keys. and ur phone is formatted now.
4) When finished, it asks for restart of phone.
5) Restart ur phone, and ur phone is ready.
Sep 09, 2007 | Nokia 3230
Samsung Blackjack SGH-I607 Smartphone Logo
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
