Question about Weather King 10AJA2501AH Air Conditioner
Outside Fan Problems
The AC fan outside has started to stop working. When i turn it off for 5 minutes or more and turn it back on it sarts back up or sometimes it does not turn but looks like it is trying. I can give it a nudge and the fans comes on. It still stops running after anything from 5 minutes to running fien for several days.
Now it is only runnig for about five minutes and the fan just stops running. Everything else stays on but I turn it off because I know it should not run without the fan running. Is this the capcitor causing this or my fan motor. I'm thinking of putting in a new capcitor. What do you think?!
  • 80 Answers
TRY CHANGING THE CAP FIRST BUT MOST UNITS ONLY USE THE CAP TO START THE MOTOR NOT TO KEEP IT RUNNING SO IT SOUNDS LIKE YOU HAVE A BAD CAP AND THATS WHY IT DOESNT START HOWEVER IF IT STOPS RUNNING WITHOUT THE THERMOSTAT TELLING IT TO (OR IN THE MIDDLE OF A CYCLE) THEN YOUR RUN WINDING IN YOUR MOTOR IS GOING BAD YOU CAN REPLACE THIS MOTOR PRETTY EASY AND IF YOU USE AN AFTER MARKET INSTEAD OF AN OEM MOTOR YOU CAN SAVE YOURSELF ALOT OF MONEY. PS BE CAREFULL WHEN CHANGING YOUR CAP BECAUSE EVEN WITH THE POWER OFF IT CAN SHOCK YOU.AFTER SHUTTING THE POWER OFF USE AN INSULATED SCREWDRIVER AND TOUCH IT ACROSS THE POLES AT THE TOP OF THE CAP TO GROUND IT AND REMOVE POTENTIAL ENERGY.
Posted on Jul 24, 2008
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Compressor fails to restart
indicates that the compressor is not communicating with the program board in the inside unit
could be a relay problem
call in the service technicians for a proper diaganosis
Sep 12, 2017 | Honeywell Heating & Cooling
Ac blower in mobile home starts then stops
e.o oddly i remember seeing an AC blower doing this outside of its system it seems to me the control box on the blower isnt really seeming to know what to do since its all controlled electrically and if its getting mixed inpulses then the control box itself can get confused on knowing what to do such as fan speed and controlling it to turn off and on....most likely the control box isnt working as it should and may need replacement or have an electrical guy check things out
Apr 16, 2017 | Heating & Cooling
Turned on AC was running fine. 30 minutes later began to hear a strange noise. Opened AC/Furnance closet & heard a sound best described as air letting out of a tire. It seemed to be coming from...
Hi!!
This means that the condenser fan motor (outside unit) failed, this caused to build hi pressure and either activated a safety valve to release the extra pressure or blew a line and R22 Refrigerant escaped from system.
The fix is to replace motor fan and capacitor find the leak and refill system with R22 Refrigerant Gas. It is safe to turn on the Fan Only mode on the Thermostat until a HVAC Tech arrives.
To perform this job parts and labor included will cost: about $300 -.$400. Look on the Yellow Pages for a Tech in your neighborhood.
Good Luck!! Don't forget to Rate this post!!
Aug 13, 2010 | Goodman CKL42AR42 Air Conditioner
Outside unit kicks on but inside fan sometime works and sometimes won't and i have replaced thermostat to get to work i have to turn the fan to on and back to auto several times and finally the fan inside...
Goodman air handlers (inside unit) fan have a delay timer that turn on the fan ,sometimes up to 3 minutes after the outside unit is on,this makes the a/c more efficiency.
Sep 19, 2009 | Goodman CKL36AR36 Air Conditioner
AC fan not working
turn it off call repairman
Jul 11, 2009 | Heating & Cooling
I live in south texas overnight the ac stopped GOODMAN MODEL
Is the condenser fan (outside) turning? You mention that it's hot but don't say if it's turning or not.
These fan motors normally run pretty hot, but not so much that they shut down due to internal thermal overload protectors.
Both the compressor and the fan have termperature overload protectors to keep them from burning out the motor in the event of an overheated condition. The condenser fan must be running or high freon pressure will put an excessive load on the compressor and it will 'kick out' the high-temp overload protector.
Turn off the unit by pulling the outside disconnect (in a small box near the outside compressor unit) or flip the AC breakers in the breaker box. Wait about 30 minutes for the unit to cool off and turn it back on. If the compressor and fan both run for awhile then kick back off, or the fan motor seems to be working under excessive strain, you've probably got a bad motor start condenser (inside the unit) that little round can that is connected through the fan motor wiring. If it's swollen or leaking, it's almost surely defective and even if it's not, excessive load on the motor is a classic sign of a bad start condenser.
You can usually find these at electrical supply stores, well-stocked hardware stores, or most certainly at an HVAC parts house. Be sure to replace the old one with one of the EXACT same value (in voltage and Microfarads (mF) capacity. The shape may be a little different, but as long as the electrical characteristics are the same and is rated at the same or higher voltage than the original, it will work.
Connect the new condenser, mount it to the frame, and restart the unit. This should take care of the problem.
Hope this helps.
Jun 28, 2009 | Heating & Cooling
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
Weather King 10AJA2501AH Air Conditioner Logo
110 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
