Question about Canon PIXMA MP780 All-In-One InkJet Printer
LINES ON FAXES
ONLY FAXES ARE GOING THROUGH AND COMING THROUGH WITH LINES ALL DOWN ONE SIDE OF THE PAPER
  • Anonymous Oct 04, 2008
    Color lines down one side of scanned documents, sounds like similar problem.
I washed the Glass!!!
Posted on Jul 23, 2008
I HAVE BLACK LINES DOWN EACH SIDE OF MY FAXES THAT I DONT KNOW HOW TO GET RID OF
If they are on the faxes that you send you need to clean the reading glass; open the cover where you place your originals when faxing and look in there and there is a thin glass that runs left to right. Clean the glass with a lint free cloth and glass cleaner with out ammonia or some rubbing alcohol.
If the lines are on your incoming faxes it is most likely from your drum. Replace your drum and that will most likely correct the problem.
Jan 14, 2011 | OKIFAX 5650 Plain Paper LED Fax
When faxing a paper and the recipient receives the fax, their copy has a wide black lines down the side....if we make a copy, it has wide black lines down the side....we have replaced the drummer we've...
FIRST I would check the scanner glass again you can test it by asking for a report to be printed..ie tx REPORT.. if this dowsnt have a line on it the problem is either the scanner glass or at worst the scanner unit it self.. I would double check the glass.. get a soft cloth and some glass cleaner on it and give the glass a good rub over. do you have the lines on incoming faxes .. if not the glass or scanner unit is the def area to be looking at, Luck A
Aug 27, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Please help - faxes not going through. "function not completed" NG #018 is this an error code?
is it doing it on all out going faxes or just a few ? #018 means the other side was busy or out of paper or not in service.
Jan 26, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
When we recieve Fax, the paper is very dark
We had the same problem and we switched out the drum and now the faxes are very clear except for a solid black line going down the right side of the paper.
Mar 14, 2009 | Brother IntelliFAX 2800 Laser Fax
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Black lines on faxes
Open up the document feeder (where you put paper to send) and look for wite-out on the thin glass.
If it's not dirty, you probably have a bad scanner unit. Uneconomical to repair.
Sep 23, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Bad copies
take out toner cartridge shake from left to right and reinstall cartridge
Jan 23, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
32 people viewed this question
old marine
old marine
