Question about Teac GF-350 CD Shelf System
Turntable not turning to play record............. power on............ please help my email address - diatmesa@aol.com
  • diatmesa Jul 22, 2008
    turntable
This could be many things like the following>
If its a direct drive turntable the motor could be "blown",
or motor electonic speed controller burnt out.
If its a belt drive turntable then the belt could be broken
or stretched and is slipping, or the belt can have dropped of a drive pullety.
Also there are speed control mechanisms to adjust the final speed of the
turntable to the recorded speed of the record like 331/3rpm, 45rpm 75rpm
These speed reducing mechanisims can slip and cause the turntable not to turn..
There are also other mechanical bits that slide and push against each other,
and these can get sticky and the friction increases so much that the power
from the motor drive causes the belts to slip, so you need to identify if a
friction problem exists as well..
If you are carefull you can look your self and find out which one of the above it is.
Be warned there are lethal voltages inside the turntable which can kill you....
so please dont have the power on when making any inspection or adjustments.
Cheers From YUBEUT..
Posted on Sep 27, 2008
Record player not working when i turn power on
Not playing how? Won't spin? No audio? For more information, please visit my website at audioserviceclinic.com. Thank you.
Oct 09, 2013 | Crosley CR248 Turntable
Setting up facebook account with email it is supposed to be mnavyson@aol.com, which shows up at aol for my mail. i can not find a way to fix the facebook to say mnavyson rather then navyson. Can u...
make sure youre email address and facebook email address was the same first cahnge youre email address that may fit on youre face book account..
Mar 08, 2011 | Facebook Social Network
I also got a Samsung T706 Tiny Book and can;t set up wireless.It does not recognized Net Gear. I can,t even connect to my AOL emai. I just hangs and Tiny Book does not have an email address. Please help' I...
I just purchased a Samsung Tiny Book with Windows Embedded CE 6.0 and like a lot of people I had trouble finding the Wifi. I played around with the computer for about an hour but I found it; Cick "Run" type in /windows/wifi.exe click "OK". That should turn your wifi on. Then go down to the right hand corner, click on the little computers icon (they most likey have a red X over them) and this will give you your available wifi options. Hope this helps
Nov 12, 2009 | Computers & Internet
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
My turntable starts in the middle of the record only after me helping it start spinning.
you need a flat key that slots in where the rubber grommit is on the turntable platform. Remove the rubber stopper, use a flat head screwdriver into the slot inside the hole, out an old record on the turntable, and try the play button to see where the arm now lands ( dont forget to put the stylus protector on to prevent needle damage! ) and then keep making small adjustments till the arm starts at the beginning of the record. I actually have an original sony flat key should you want it? but to be honest a long shaft screwdriver is perfectly adequate for the task? email me at lesliemurphy_964@msn.com if you want the key though?
Les Murphy
Aug 15, 2009 | Sony PS-LX250H Turntable
I'm using the TTYSB05 turntable for the first
There is a raise/lower button. To lower the tonearm, the button should be in the out position.
Apr 07, 2009 | ION Audio Vinyl Recording Turntable
Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
Hello, My company uses Outlook Web Acess connected to Microsoft Exchange. My personal email is AOL...Im trying to export a group of e-mails from AOL to Outlook WA email? AOL Tech support cannot...
HI Azkinney,
I can help you it's not pretty but it works without downloading or buying any programs.
1- create an email with your aol interface
2- open your address book and add everyone
3- don't send the email but select the addresses you have in your "TO" field of the email you created
4- copy the selected addresses to a word processing program like word pad
5- save the new document as a .txt file
6- open this document with Microsoft excel
7- export the document with a CSV file format
8- outlook can import CSV files into the address book
You know its a lot of steps but its the simplest way I have found since AOL hates their customers using other emails and will be as much help as a canker sore on your nose.
I hope this helped. Please don't forget to rate the answer it helps me with my solutions.
Nov 13, 2008 | Computers & Internet
Teac GF-350 CD Shelf System Logo
922 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
