Question about Paradyne 6381 ADSL2+/ReachDSL Router (6381A3200)
Using both USB and Ethernet to connect to the internet
i have 2 pcs that i use to connect to the internet, i currently use a paradyne 6381-a3 router/modem to connect to the internet (adsl), it is configured as a bridge and dhcp is enabled. i am using the ethernet port to connect and it assigns ip addresses automatically when connected to a pc, however only one pc can be used at one time.
i want to to use both usb and ethernet ports on the router to connect both pcs at the same time. is that possible? one pc will connect via ethernet and the other via usb, simultaneously.
please assist in a solution, any help will be appreciated.
Raul
  • 1 more comment
  • Raul J Jul 28, 2008
    Yes, the router supports USB ports, I can connect to the Internet via the USB port also, once I am not connected on the Ethernet port. It's either Ethernet or USB, both works perfectly, but not at the same time, it's either or.
  • Raul J Aug 15, 2008
    It's a DSL Modem/Router, a modem that can be configured as a router, presently configured as a modem, I can configure it as a router when needed. I know I can get a wireless router and make it work, but I was just wondering whether it can be done on the DSL Modem/Router alone, without the use of another router.
    There are two (2) main interfaces to the Modem/Router, being USB and Ethernet. There are LAN Groups that can be configured with different IP ranges. I am thinking if I put the Ethernet interface in one LAN Group and the USB interface in another LAN Group, both with different IP ranges, it might work. However, all the interfaces are in LAN Group 1 and I can't get any to move from that LAN Group.
    Any help is appreciated. Thank you
  • sesadri Apr 30, 2009
    I have two PCs. i am having BSNL dataone connetction through the Router which is provided by the BSNL office. This router having tow ports one is USB and another is Eathernet.
    My problem is, i want to use the two computers by using USB port and eaternet port at same time without diconnecting the net .
    can any body solve this problem?
    Novelist:
  • 173 Answers
Does your router suports usb ports, normally routers do not support usb ports, please check if your router first suports usb ports
Posted on Jul 27, 2008
  • mohana sundaram Aug 15, 2008
    so its just a dsl modem not a router.. get a wireless router so that you can access both your desktop and laptop simultaneously
My company provided me wired internet using Paradyne 6381 wired modem. it works fine. I have D Link 2640 T wirelss modem + router available with me. Please advise me how do I connect available D link 2640...
Since your D-Link 2640 is a modem + router it may not work the way you intend.
You need just a wireless router without modem.
Run a small Ethernet patch cable from your Paradyne modem into the WAN port on your router, you can plug your existing Ethernet cable into one of the other LAN ports on the router, then access the router setup using the computer connected to the Ethernet cable using a browser and putting the router's IP address into the address line of your browser. It will most likely be 192.168.0.1 or 192.168.1.1.
Once you have configured the Wi-Fi router you will have your wireless network. Full instructions should come with the router.
Routers are available for as little as $29.95 but expect to pay closer to $79.95 for satisfactory speed and capability.
Oct 23, 2017 | Paradyne ADSL/R 6381 Router (6381-a2-200)
What is the ip address of paradyne 6381 a3 300 router
To configure your router, open your web browser. Type the default IP address (http://192.168.1.1) into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default IP address is 192.168.1.1
The default user name is Admin
The default password is Admin
Both are case-sensitive.
Jan 08, 2010 | Paradyne ADSL/R 6381 Router (6381-a2-200)
Using both USB and Ethernet port to connect to the Internet
Hi; I have used it with both ethernet and usb connections at the same time. I have never used the bridge, but I use it at home.
Try this ( I have XP SP3): Right-click on the monitors where the clock is (lower right corner), select "Open Network Connections". Go to the LAN connection and r-click "Properties". On the "general" tab select "Internet Protocol (TCP/IP)". There you select "Obtain IP address automatically" and "Obtain DNS server automatically" then click "Ok" until exit. Either Shut Down or Restart the PC. Check if this work.
Jul 19, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Trying to set up pptp on a Paradyne 6381
I have modems 6381-A2-200, sw ver.03.00.10. This model does not support pptp-connection.
Dec 06, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
6381-A3-302,6211-I1-300 Paradyne ADSL 2+/Bridge Router
i have paradyne paradyne 6381 a3 302 lost the driver cd. My new windows xp don't pick it automaticly. plz give me a slution.
Nov 22, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
Paradyne Dsl Modem
Hi, If I understand you right, what you want is to use your Paradyne 6211 modem to share the Internet connection to 2 PCs. One is connected through the USB and the second through Ethernet port. Tried it on a Siemens 4200 and a Prolink Hurricane 9000, both worked and can be done. To be sure, the IP settings of the PC connected via Ethernet was set to manual configuration. In your case try IP 192.168.1.3, Subnet Mask 255.255.255.0, Default Gateway 192.168.1.1, DNS Servers - whatever your ISP are using. You of course can try and see if it works in your modem. Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 03, 2007 | Paradyne (6211-A2-200) Router
Paradyne 6381 ADSL2+/ReachDSL Router (6381A3200) Logo
410 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
