Question about GE 31GT660 TV
Fuse blows I recently moved, TV worked fine. Packed it in the truck very well. Moved from Ohio to Florida. Pluged TV in 2 days after unpacking, fuse blows instantly, Cleaned circuit board with soft brush and low pressure air replaced fuse----then pluged it in----again it blows.
  • GE Master
  • 5,138 Answers
You have a shorted rectifer diode,also ck fuse resistor its the big white one 2.7 ohms 7 to10 watts.and your hori outout transistor.
Posted on Jul 26, 2008
I have a 2008 harley davison heritage softail Blow the ignition fuse. Got it home the next day it ran fine Went to auto parts to git fuse Came back put one in works Started it up 12 or more times...
i9ndicates that you have dead short problem in a component in the ignition system
could be a bad ground causing excessive current ( arcing) when component is moved or wiring moved
maybe an auto bike auto electrician could pinpoint the problem area
possible a voltage control problem causing excessive current through the fuse , intermittently causing it to blow
Again a bad ground in regulator problem
Dec 05, 2017 | Cars & Trucks
Are bike is having a little smoke coming from the exhust pipe we think it might be the antifreez we just moved from florida our manual is packed away just need alittle advice
is it blue coming from the exhaust
is it a 2 stroke if its a 2 stroke blowing blue smoke its quite normal if its blowing to much your rings might need replacing keep an eye on the ((oil level))
if its a 4 stroke and its blowing blue smoke from the exhaust keep an eye on the ((oil level)) the rings might need replacing if its burning lots of oil and blowing blue smoke your rings do need replcing
hope this helps
Mar 02, 2011 | Geovision GV-650 BNC (GV6504) Video...
RCA projection, no power, no sound. recently moved.
Ur DM power board have burn capacitors,check for puff up capacitors,and replace it.Tries these websites.Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No power
Have you checked the outlet for power if so open up set to see if fuse came out during moving it if fuse checks ok look for cold solder joints in power supply dfox230@yahoo.com
Jan 24, 2009 | Insignia NS-30HTV 30" TV
Re: Kenwood DV 605 CD Player... Power On: Reads "Loading." All 5 CD lights are lit up but the CD changer does not turn. CD #1 appears on screen with two green lights appearing.
ace71cf.jpg We repaired this problem by taking the advice of another member of FixYa! The component had recently been packed to be shipped. After unpacking the unit when we powered up the read out only displayed "LOADING" and the CD changer door would not open. We removed the exterior cover and gently moved the CD changer one position. When it locked back into position we powered up and the unit works fine now. FixYa sure help me save perhaps a $100. or more by not sending it to the manufacturer or another shop. And it was working within minutes so we could enjoy using it right away. Thanks guys I very much will recommend this sevice to others... this was the 2nd problem we fixed that day by logging onto FixYa!!!
Z-Dawg
Dec 06, 2008 | Kenwood DV-605 Multi-disc DVD Player
Replacement hardware for DaVinci Emily Crib
Debbie, please shoot me an email if you found your parts...I too need some parts: asparkman@att.net
Sep 15, 2008 | DaVinci Leonardo Crib
Kenmore electric dryer
ck door switch also ck connection of power cord could be burnt remove back (if top mount filter lower panel if door mount)look for white thermal fuse ck for closed circuit through fuse fuse is in motor circuit and has been known to blow for pluged or restricted vent system
Jun 10, 2008 | Kenmore Dryers
GE 31GT660 TV Logo
85 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
