Question about HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook
My laptop Orange juice got spilled into the keyboard of my laptop. The computer is working fine but all the keys are sticking. How do I clean it?
    Genius:
  • 2,028 Answers
I'll start by telling you that most of the time keyboards don't recover from a spill. With that said, clean it by using a 50/50 rubbing alcohol in a spray bottle. Remove the keyboard from the machine, and spray the alcohol into the keyboard generously. Shake out the excess or blow it out with air, then use paper towels to daub up the rest. Repeat this process two or three times, then let the keyboard dry for a good 24 hours. While you have the keyboard off check for any juice or sticky areas in the machine, and clean them with the alcohol and Q-tips. Let this dry well also. After drying put the keyboard back on and try it. If you notice any sticky keys after using it for a while, then take the sticky keys off and clean them individually with the alcohol and Q-tips.
Posted on Jul 22, 2008
How do I clean my keyboard on toughbook cf53. I spilled juice on it and the keys are sticking and hard to use now.
It is a toughbook so don't be afraid to use a damp sponge to try and clean out the sticky sugarly juice. Increase the amount of water in the sponge as you go along until it gets clean enough to work correctly. Leave the laptop upside down while doing this to prevent the water from carrying the juice further into the keyboard. If you know how to remove the keyboard, I've successfully washed it with running water and letting it dry out vertically so excess water runs out to an edge. If the heating system is on, I've done this on a radiator or heating vent.
Oct 06, 2014 | Panasonic Toughbook Cf-53aug781m Notebook...
Spilled juice on my keyboard hp presario cq57 now some keys dont work what can i do
that is not possible to clean the keyboard needs to be replaced but its cheap enough should be below 80,- check electronicpartner.ie they have free collection
Feb 19, 2013 | HP Compaq Presario CQ57-229WM Notebook PC
I spilled orange juice on my pc keyboard unscrewed the screws in the back took it apart really sticky what should i clean it with
It is impossible to clean it, especially when the computer was powered up when you spilled orange juice on the keyboard, it most likely shorted out some components in the keyboard.
I suggest you buy a new keyboard.
Feb 25, 2011 | ASUS Computers & Internet
Toshiba Satellie L305D-S5974--spilled orange juice on keyboard, keys sticking, speakers not working...what are my choices
When this happens, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Nov 30, 2010 | Toshiba Computers & Internet
My keys are sticking due to orange juice being spilled on them. My IT guy at work said I could order another keyboard or keypad, how do I do that and where can I order it from, he will change them out for...
Go to ebay and enter your computers info"" make and model...alot of choices will pop up.Select the one that suits you.It's really that easy.I only hope none of that liquid went futher than the keypad...Goodluck
Apr 07, 2010 | Gateway 2520915 Keyboard
Spilled juice on my H P Pavilion laptop keyboard, keyboard is not working at all. Please help!
Do you have an HP Accidental Damage extended warranty? If you do, you can call HP's tech support and get it fixed/replaced.
If you don't have the extra warranty, you can try to carefully pop the keyboard keys off and carefully clean underneath as the contacts below the keys are possibly stuck in the down position.
You may have to take it to a service centre and have a technician open up the laptop and see if it can be cleaned and try to "unstuck" the keyboard keys.
Apr 12, 2009 | Computers & Internet
Spill soda on my laptop keyboard
It is likely the only problem is that the soda is causing the keys to stick. There is probably no damage to any other internal components. Usually, laptop keyboards have a metal-based frame/tray that will protect the internal components from minor spills.
If you want to get rid of the cracking sound, you'll need to purchase a replacement keyboard from the laptop manufacturer or another source such as eBay, and then remove the sticky keyboard and replace it with the newly purchased one.
Mar 23, 2009 | Toshiba Satellite L305D-S5895 Notebook
Spilled Grape Juice
To give it a good cleaning, you will need to remove the keyboard and clean anywhere you can see juice or feel stickiness. You can buy the expensive computer cleaners, but I suggest 50/50 rubbing alcohol and Q-tips. Remove the battery and C-mos battery to make sure there is absolutely no power to the machine what so ever. After cleaning inside, you will want to give it a good 24 hours to dry, ensure that there is no moisture before applying power. If the juice reached the bottom of the machine, you may need to remove the screen, split the cases, and take the motherboard out, in order to clean the bottom side of the board. If you leave juice anywhere on the board it will gum up, and the acids in the juice will corrode and detierate the circuitry on the board causing a motherboard failure. Now the keyboard, in order to thoroughly clean the keyboard, I suggest that you spray a good amount of the rubbing alcohol in the keyboard, shake it or blow it out with air, then take paper towels and daub up the rest. Repeat this two or three times, then let it dry approx 24 hours. Sometimes the keyboard won't recover after a spill and will need replaced. If it works properly, then, after using the keyboard for a while, you will notice if any of the keys are sticking. Take the sticky key or keys off and clean them individually. I know it's alot of work, but it'll teach you not to keep open drinks around your laptop. It did me, I've ruined one machine, two keyboards, and thoroughly cleaned a third very expensive machine of mine to keep it working, but I finally learned to drink from a sippy around my laptops.
Jul 21, 2008 | Dell Inspiron E1505 Notebook
HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook Logo
295 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
