Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart Sense-a-Temp booster heater
How do I reprogram the heater for the Hobart Dishwasher?
  • gary marzian May 11, 2010
    why do you want to change the program
  • Cecil Colvin
    Cecil Colvin May 11, 2010
    Please provide make and model of dish washer
  • 640 Answers
What heater,wash tank or booster and why?
Posted on Feb 21, 2009
Rinse cycle not working
it seems like control board malfunction.
May 30, 2016 | Hobart AM-15 - Commercial Dishwasher -...
Rinse temperature too low
your right dont guess the board is bad!
Aug 08, 2012 | Hobart AM14C-155 Dishwasher
Hobart LX 30 undercounter dishwasher, commercial Does this model require booster?
Most of the Hobart LX series of dishwashers have their own built-in booster heaters. To check for one, remove the lower front panel (2 screws). The booster heater, if present, will be a stainless steel tank on the left side. If it doesn't have a built in booster heater then it was meant to be used with chemical sanitizer instead.
Jun 29, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Good morning, I have 01 Hobart dishwasher AM14, i need to be replace rinse sensor probe and temperature sensor for booster heater.But I can't to find Hobart part number Please help me.Thank you.
294692 for the rinse probe.
"temperature sensor for booster heater"? Do you mean the thermostat? If so, part number is 274161.
Parts breakdowns and part numbers are available at www.hobartservice.com. Click "Parts" on the left, then click "Hobart SmartParts System" on the next page. You'll be asked a series of questions to identify your piece of equipment, and then you'll get a parts list and have links to parts breakdowns for various sections of the machine.
Nov 20, 2010 | Hobart AM14C-155 Dishwasher
I have a hobart lxih that fill runs once and steam comes out on rinse than flashes P3
Probably a bad booster tank termperature probe (thermistor). This is threaded into the booster heater and has two small black wires entering it.
The following procedure will result in a some water coming out of the booster heater. Allow the booster heater to completely cool, and shut off the circuit breaker for the dishwasher before proceding.
Prepare a new temp. probe with teflon tape, then unscrew the old probe from the booster heater and quickly install the new probe. Assuming the heater is cooled, you can hold your finger over the hole vacated by the old probe to prevent excessive water from pouring out of the booster heater.
Oct 22, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Do all Hobart dishwashers have a element in them for wash water and rinse water
All Hobart dishwashers will have a wash tank heating element, but the rinse water is not heated by the dishwasher, unless it has a built-in booster heater. Usually a separate booster heater is used to heat rinse water to 180-190 deg. F for hot water sanitation.
Aug 07, 2010 | Hobart AM14C-155 Dishwasher
I will be hooking up this dishwasher.
I'm a hobart tech.If the dishwasher is going to be a cold machine you need 140 degrees,if its a hot machine you need 180 which you need a booster.A hatco c-36 will supply the dishwasher with180-190 degrees.Any ? let me know.
Jan 15, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Hobart LX30
Hopefully you took the suggestion to run the correct 50 amp 208-240 service to the unit.
Converting the unit to an LX30C has a couple of pitfalls. The LX30C is connected directly to the incoming water supply, which should run 120-140 degrees. By reprogramming the unit as an LX30C, the booster would be disabled, which would mean the incoming water would flow through the de-energized booster and be cooling off while it sits in there between cycles and when the unit is shut down.
The incoming fill plumbing (5/8" heater hose) would have to reconnected from the fill solenoid valve directly to the vacuum breaker on the rear of the unit to bypass the booster heater.
On the 208-240 volt LX18/30/40's, the pump motor, booster heater, and sump heater run on 208-240. To convert it to 120 volts you would have to replace the sump heater and reconfigure the motor wiring in the motor junction box.
By the time this is all done, you've downgraded a great machine, confused the next service guy, and have to deal with nasty chlorine and all of it's headaches.
I
Aug 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
303 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
