Question about Olevia LT23HVX 23 in. LCD Television
I have Olevia LT23HVX tv/pc monitor. Im trying to hook it up to my home pc but it keeps on saying OUT OF RANGE under pc. But for the tv is fine can youo help please.
    Brigadier General:
  • 8,909 Answers
"Out of range" meand the screen resolution of your PC doesn't equal the input possibilities of your screen
Check the resolution is compatible.
Posted on Feb 07, 2011
SOURCE:
I'm looking for an owners manual for an Olevia 332-B11 it is approx. 10 years old. Any help?
Free User Manuals and Owners Guides ManualsOnline com
Try this site. It goes faster if you have the serial number and the make handy.
hope you find your manual,
kolbrun
Feb 01, 2015 | Olevia Televison & Video
When i connect my computer to it it says out of range
Out of range simply means you have set the resolution too high thats all and you should lower it.
Apr 13, 2011 | Olevia LT23HVX 23 in. LCD Television
My lt23hvx power button does not work. I keep pressing the power button to turn on and it will not turn on
If you're trying from the remote control, then try from the TV and see if it works. Or vice versa... Also, make sure the TV is plugged in (you would be really surprised to see how often this is a problem).
If there is no noise and no lights, then odds are your power supply is faulty. For that tv, you're looking at a replacement of less than $100.
Cheers, -SJ
Mar 08, 2011 | Olevia LT23HVX 23 in. LCD Television
Receive an invalid format message from my Olevia 32 tv
You get invalid format, or format not support becuase the video resolution setting on your PC is too high for the monitor to display, you need to lower your PC video resolution to the native resolution of the TV to get the best picture. Look at the owner manual for your TV or search the web.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 11, 2010 | Olevia LT32HVM 32 in. LCD Television
Hooked to pc....starts up fine at
check your hd settings are correct on your pc.
Apr 28, 2009 | Olevia LT23HVX 23 in. LCD Television
I need a driver for my LT23HVX Olevia Display
Since this is a TV, you do not require a driver for it or any display device attached to a PC. The driver you need to update is the video card driver of your PC.  Once it is installed, it will be able to communicate with your TV or monitor's EDID (Extended Display Information Data) and be able to send an image to it properly.  The internal EDID will tell the video card what resolutions it can accept.
Mar 24, 2009 | Olevia LT23HVX 23 in. LCD Television
My olevia LT23HVX does not power on
Try unplugging and replugging after waiting.
Jun 13, 2008 | Olevia LT23HVX 23 in. LCD Television
Olevia won't turn on.
I posted photos and a description of my solution for this problem here: http://www.flickr.com/photos/geegee123/sets/72157607269121264/ There's another thread on FixYa dealing with this same issue that has a variety of solutions as well.
Mar 04, 2008 | Olevia LT23HVX 23 in. LCD Television
Olevia 23 LT23HVX
i just fixed 1 that was dead it had three capacitors bad on power supply board the numbers are on the board beside the parts , [email protected], [email protected] , AND [email protected] THESE THREE PARTS WERE BAD KEEPING SET FROM STARTING UP ON MY SET THE CAPACITORS WERE BULGING AT THE TOP AND READING HIGH ESR READING.HOPE THIS HELPS YOU FIX YOURS. STEVE H OR DOGSET.
Jan 31, 2008 | Olevia LT23HVX 23 in. LCD Television
Olevia LT23HVX screen resolution
what kind of cable are you connecting with? If you are using a Composite or S-Video cable perhaps you may want to use the VGA cable instead and see if that corrects the issue.
Nov 29, 2007 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
171 people viewed this question
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
